ᐅ Floor Plan for a 200 sqm Urban Villa – Are Our Requirements Feasible?
Created on: 13 Jul 2020 14:14
ECE-2021
I’m a bit overwhelmed with our floor plan and keep running into the same problems...
The main issue is probably how to integrate a straight staircase from the ground floor to the upper floor, and how we would have to modify or extend the hallway to fit such a staircase without "breaking up" the other rooms.
Plot size: 1005 m² (0.25 acres)
Slope: no
Site coverage ratio: according to neighboring developments
Floor area ratio: according to neighboring developments
Building envelope, building line, and boundary: according to neighboring developments
Edge development: no
Number of parking spaces: double / large garage planned
Number of stories: 2
Roof type: hipped roof
Style: urban villa
Orientation: street facing northeast, plot extends sideways toward west-northwest, garden planned all around southwest / west-northwest
Client requirements
Style, roof type, building type: urban villa with hipped roof
Basement, floors: basement + ground floor + upper floor
Number of occupants, ages: 2 adults + young child (3)
Office: home office?
Closed architecture
Closed kitchen, kitchen island
Fireplace
Balcony
Garage
Who designed the plan:
- Option 1: planner from a construction company (not yet an architect)
- Option 2: do-it-yourself
Overall, the floor plan is good and was implemented largely according to our ideas.
What do you dislike? Why?
We would prefer a straight staircase. According to a staircase calculator tool, it would require a length of 3.70 m (12 ft).
From research, this might be rather uncomfortable and therefore unrealistic.
We would be willing to extend the hallway for the straight staircase if necessary.
Symmetry, especially in the front view of the house, is very important to us, so we want to keep the type of front door as is.
The awkward corner in the upper hallway is not very appealing (bedroom / office).
Furthermore, the hallway window was initially placed in the child’s bedroom, but that will be changed so there is natural light in the upper floor hallway.
I’m also wondering if the chimney flue on the upper floor can still be routed freely, possibly offset within the ceiling/floor. Or does it have to go straight up from the ground floor fireplace? Because then it would end up right in the middle of the upper floor hallway.
If you have to give up something, which details or fittings could you do without?
- Could you compromise on: I’m open to suggestions for now
- Cannot compromise on: ideally the straight staircase
See differences between our design and the construction company’s plan
- straight staircase instead of quarter-turn
- kitchen recessed
- window in the hallway instead of in the child’s room
- ideally no hallway obstruction on the upper floor
Slope: no
Style: urban villa
Client requirements
Closed architecture
Fireplace
Balcony
Garage
- kitchen recessed
Würfel* schrieb:
made of raw steel. Only oiled.With all due respect, that sounds very strange: nothing soaks into metal, and it’s not exposed to motion with friction against other metal parts either, so what’s the purpose?https://www.instagram.com/11antgmxde/
That sounds, with all due respect, very strange:This is more of a surface sealing caused by the oil. Otherwise, the steel would eventually rust from humidity in the air, hand or foot sweat, or damp wiping. It works well, the oil was applied very thinly with a cloth and somehow absorbed or disappeared.
@ECE-2021 … unfortunately, a site plan is missing here to understand the floor plan situation.
And then … a straight staircase, what you calculated just doesn’t work at all.
This will be an extremely steep staircase.
Floor-to-floor height is 325 cm (128 inches) with a clear ceiling height of 286 cm (113 inches), which is 22 to 36 cm (9 to 14 inches) higher than the “normal” standard.
Therefore, the following lengths should be planned for a staircase:
So, the staircase length should be around 450 cm (177 inches) instead of 370 cm (146 inches). It’s not enough to just move the staircase a little in the floor plan.
Otherwise, I agree with many comments here and recommend reconsidering the living concept as well. Besides a closed kitchen or a fully open layout, there is also:
- Cooking and dining with a large table by the terrace
- Living area with sofa/TV/reading corner in a separate room with a garden view
