ᐅ Floor plan 175 sqm gable roof without basement
Created on: 24 Feb 2023 20:55
s_mhofma
Plot size: 612
Slope: No
Floor area ratio
Plot ratio
Edge development: Yes. Construction directly on the street and 3 meters (10 feet) distance to neighbors on each side, so no flexibility in width
Number of floors
Roof type: Gable roof, 30 degrees pitch
Architectural style
Orientation: West/East
Maximum heights / limits: 3 meters (10 feet) distance to neighbors on each side, so no flexibility in width
Further requirements
Homeowners’ Requirements
Architectural style, roof type, building type
Basement, floors: No basement, 2 floors, knee wall 1.80 m (6 feet)
Number of occupants, ages: 2 adults, 2 children
Office: Family use or home office? Home office
Overnight guests per year: Many
Open or closed architecture; open
Traditional or modern design
Open kitchen, kitchen island: Kitchen with island and concealed pantry
Number of dining seats: 8
Fireplace: No
Music / stereo wall
Balcony, roof terrace
Garage, carport: Garage
Utility garden, greenhouse
Other wishes / special features / daily routine, including reasons why certain things are or are not desired
Designer: Architect
- Planning company
- Architect
- Do-it-Yourself
What do you especially like? Why?
What do you not like? Why?
Personal budget limit for the house, including fittings:
Preferred heating technology:
If You Have to Give Up on which details / expansions
- can you give up:
- cannot give up:
Why Is the Design the Way It Is? For example:
The house is located directly on the street. Distance to the neighbors on both sides is 3 meters (10 feet), so no possibility to adjust the width.
The entrance is on the side. Since the house faces the street, the living room, dining area, and kitchen are planned on the north side, facing the garden. All other rooms face the street side. Knee wall is 1.80 m (6 feet), roof pitch 30 degrees. Bedrooms and bathroom also face the garden side.
The pantry is currently hidden but we are considering integrating it into the technical room. Underfloor heating with heat pump. Photovoltaic system is also installed (west side).
What Is the Most Important / Fundamental Question About the Floor Plan in 130 Characters?
See above
Floor plan of a house with living/dining area, kitchen, hallway, guest room, utility room, shower/WC, garage.
Upper floor plan: master bedroom, 2 kids’ bedrooms, bathroom, study, hallway.
Architectural section of a two-story house with staircase, interior, and dimension lines.
Modern two-story house with white facade, black roof, large windows, and balconies.
White modern single-family house with grey gable roof and large windows.
Two-story house with white facade, grey gable roof, and integrated garage.
Modern white single-family house with dark gable roof, large windows, and garage.
kbt09
26 Feb 2023 10:27
The measurements are unreadable... compare them with the dimensions I measured myself... do they actually match?
K a t j a26 Feb 2023 10:28
I will check in later this evening...
s_mhofma
26 Feb 2023 10:28
kbt09 schrieb:
I’ve now used CorelDRAW to roughly measure the dimensions and placed an elongated house. I find the floor plan by @saralina87 quite suitable.
Light brown ... possible terrace
Dark brown lines – fence to ensure garden privacy
Overall, I think windows could be placed all around, which seems especially important since the south side won’t have large windows. In general, I would recommend a full-height upper floor rather than an attic with knee walls of 180 cm (71 inches).
A question I still have: Is the 30° roof pitch mandatory or just a preference?
EDIT: I just saw the post mentioning that the garage does not have to be built on the boundary but can be set back 5 m (16 feet). How about a carport? Does your car really need a garage? Would a carport with an attached bicycle or garden shed be an option ... on the green area?
[ATTACH alt="1677402539674.png"]78532[/ATTACH]
Thanks a lot. Let’s take a look at this right away. A garage is not mandatory; a carport with a shed is also fine.
s_mhofma
26 Feb 2023 10:31
kbt09 schrieb:
You can’t read the measurements... compare them with the dimensions I measured... do they roughly match?
Yes, that’s about right. At the top, it’s approximately 18.3 meters (60 feet). From the bottom right to the bend, it’s about 10.5 meters (34.5 feet), and then from there to the boundary on the right, it’s another 25 meters (82 feet).
s_mhofma
26 Feb 2023 10:32
K a t j a schrieb:
I will check in again this evening...
Many thanks for the support!
hanse987
26 Feb 2023 10:40
s_mhofma schrieb:
Underfloor heating with heat pump is currently planned
Thinking back to the previous plan: if the garage is going to be on the right, where would the architect have placed the outdoor unit of the heat pump?
