ᐅ Doors: drop-down threshold seal
Created on: 27 Oct 2015 14:31
daytona
daytona
27 Oct 2015 14:31
Hello again,
a craftsman just installed a new door to our meeting room. New to me: a door with a drop-down bottom seal. Is it worth it for a residential home in terms of drafts and soundproofing?
Around 30€ (about $32) more per door?
Sebastian79
27 Oct 2015 14:32
Do you mean the bottom threshold or a drop-down rubber seal on the door? Most likely the latter with that additional cost.
daytona
27 Oct 2015 14:34
Yes, you're right. A rubber seal that automatically extends when closing.
Sebastian79
27 Oct 2015 14:37
With the front door, this is usually not a problem because there is always a small threshold installed or a drop-down door seal is used.
For interior doors, this can be done for soundproofing, but often the door itself becomes a weak point. With ventilation systems, this is usually counterproductive.
FrankH
27 Oct 2015 15:15
I believe this is done in companies for fire protection reasons, specifically to prevent smoke from entering the stairwells in case of a fire. We have the same setup at our company, but one door often causes problems and tends to scrape until it is repaired again.
Bieber0815
27 Oct 2015 19:45
Sebastian79 schrieb:
For interior doors, this can be done for soundproofing, but usually the door itself is a weak point. And with ventilation systems, it is counterproductive
In my opinion, the sealing is the first effective measure against sound. Additionally, the entire door can be made soundproof. Conversely, a soundproof door without a drop seal, in my view, is not very effective.
In combination with ventilation systems, there are also soundproof transfer vents, or you can route the sound above the door frame, or use a transfer drop seal in the door (this causes the air to be redirected twice, resulting in sound insulation while still sealing the door at floor level). Suitable search terms could be, for example, "soundproof transfer element"; "soundproof transfer valve"; "Planet drop seal Mine-F" ...
