ᐅ Does KALLAX collect dust inside? Any solutions?
Created on: 25 Feb 2022 18:23
Berkutbi
Berkutbi
25 Feb 2022 18:23
Hello everyone, I have a question that has been on my mind for a while: Does the IKEA KALLAX shelf unit actually collect dust inside the compartments? I have the impression that quite a bit of dust accumulates there—especially in the back corners—even though I clean it regularly. I’m curious if this is a common issue with this type of shelving unit and whether its design might inherently make it prone to dust buildup. Are there any special solutions or tricks to keep the interior clean without having to empty everything out constantly? Has anyone had experience with specific covers, inserts, or cleaning methods that help with this? Thanks in advance for your tips!
Z
zarJody68
25 Feb 2022 19:05
Dust inside KALLAX shelves is actually a well-known phenomenon, mainly due to the open sides and backs that allow air circulation and therefore make it easier for dust particles to enter. The design with open compartments offers flexibility but also comes with this disadvantage.
A simple yet effective tip is to use transparent or opaque boxes or inserts that keep dust out while maintaining flexibility. Regular vacuuming with a vacuum cleaner equipped with a brush attachment is also recommended to effectively remove dust from corners. Ultimately, it should be noted that achieving complete dust-free conditions with such open shelving systems is hardly possible.
klo40
25 Feb 2022 19:27
I can offer a small cleaning tutorial:
1. First, remove everything from the shelves.
2. Wipe off the loose dust with a microfiber cloth.
3. Then use an old toothbrush or a small brush to clean the corners and edges.
4. For stubborn dust, a vacuum cleaner with a narrow crevice tool is recommended; this also helps reach deeper areas.
5. To reduce dust accumulation in the future, I suggest using boxes with lids or even custom-made inserts from plexiglass.
Common mistake: Many only wipe the surface and forget to clean the back panel properly. Dust tends to settle especially underneath and behind the boards.
DULIS
25 Feb 2022 20:03
Dust always accumulates on open shelves. Solution: use storage boxes with lids or cabinet doors. Otherwise, regular cleaning is the only option.
Palenar
26 Feb 2022 08:47
To look at the topic from a more technical perspective: KALLAX shelves, due to their open design with a back panel made of thin board material and open sides, are very prone to dust accumulation, especially in the hard-to-reach edge areas. Air circulation, caused by convection and possible air movement in the room, constantly brings in dust particles that collect mainly in inconvenient spots.
A long-term effective solution can be the installation of custom-made insert boxes, made from dust-proof materials such as plexiglass or laminated wood. This creates enclosed units that minimize dust ingress.
In addition, I recommend controlling the room’s humidity, as dust adheres better in dry air. Optimal humidity levels are between 40 and 60%.
If the extraction and cleaning technology is insufficient, it is possible to retrofit the back panels with custom-sized sealed material to reduce the number of dust traps.
zarJody68 schrieb:
The design with open compartments has the advantage of flexibility, but also comes with this disadvantage.
Exactly: flexibility versus dust protection – a trade-off depending on the usage scenario.
gauvin37
26 Feb 2022 09:14
You can also clamp upholstery fabric or thin fabric sheets onto the back. This reduces dust accumulation points and can be easily washed.
