ᐅ Does KALLAX collect dust inside? Any solutions?
Created on: 25 Feb 2022 18:23
Berkutbi
Hello everyone, I have a question that has been on my mind for a while: Does the IKEA KALLAX shelf unit actually collect dust inside the compartments? I have the impression that quite a bit of dust accumulates there—especially in the back corners—even though I clean it regularly. I’m curious if this is a common issue with this type of shelving unit and whether its design might inherently make it prone to dust buildup. Are there any special solutions or tricks to keep the interior clean without having to empty everything out constantly? Has anyone had experience with specific covers, inserts, or cleaning methods that help with this? Thanks in advance for your tips!
BARSAN
26 Feb 2022 12:37
Shelves with open sides always collect dust. I recommend installing doors—for example, the KALLAX doors from IKEA—which provide very good protection.
U
usbla
27 Feb 2022 17:05
I would like to add some comments regarding cleaning: When removing dust from the interior, be careful not to clean the shelves with too much water or harsh cleaning agents, as the material may swell.
Microfiber cloths and mild cleaning products are ideal. Specialized furniture cleaning foam products can help remove dust and dirt without damaging the material.
klo40 schrieb:
For stubborn dust, a vacuum cleaner with a narrow crevice tool is recommended
This is very useful because corners are often hard to reach, and dust tends to accumulate there.
It may also be worthwhile to avoid placing the shelves near windows or in areas that produce a lot of dust, such as floors or carpets. Additionally, air filters in the room can help reduce overall dust buildup.
Z
zarJody68
28 Feb 2022 14:12
Palenar schrieb:
Flexibility versus dust protection – a trade-off depending on the use case.
Exactly. Those using the KALLAX for neatness and quick access will likely not want to focus heavily on dust protection. On the other hand, closed inserts make sense if the main goal is to keep dust out.
As with other open shelving systems, it remains a compromise between design, functionality, and maintenance effort.
