ᐅ Wardrobe Using KALLAX as a Base – How to Prevent Looseness?
Created on: 6 Sep 2024 07:43
V
velina
V
velina
6 Sep 2024 07:43
I’m planning to design my wardrobe based on an IKEA KALLAX shelving unit because I appreciate its modular design and value for money. However, in my initial attempts, I noticed that the modules – especially when used freestanding or as room dividers – can feel somewhat “loose” and not as stable as I would like for a wardrobe. Specifically, I’m concerned about the rigidity and stability of the structure so that clothes, jackets, and accessories can hang or rest securely without the unit wobbling or warping.
Does anyone have experience with this and can offer advice on how to prevent or reduce this “looseness” in a KALLAX framework when used as a wardrobe solution? I would appreciate suggestions for reinforcements, fastenings, or practical additions that are particularly suitable for use as a wardrobe with heavier textiles.
Nabla64
6 Sep 2024 08:17
Hello velina,
a very interesting question! I’ll take a structured approach and share my tips as follows:
1. Reinforcing the back panels: The KALLAX generally has thin back panels that contribute little to stability. A proven method is to reinforce the back panels with additional wooden boards or MDF panels (5-10 mm (0.2-0.4 inches)) attached on the back by screws or staples. This provides significantly more stability against lateral warping.
2. Installing diagonal bracing: For even greater sturdiness, you can mount wooden slats diagonally on the back. This makes the frame almost indestructible against twisting.
3. Additional screw connections: When building custom constructions, it’s advisable to secure all joints with suitable wood screws (not just snap or plug connections). Often screws are not included with KALLAX, so countersunk screws can be purchased separately.
4. Fixing at floor and ceiling: If possible, secure the shelf to the floor and ceiling. This greatly increases stability, especially for freestanding wardrobes.
5. Attaching clothing rods: For heavy garments, use sturdy clothing rods (possibly fixed to the wall or side panels) so the load is not supported solely by the base frame.
If detailed measurements and photos would help, just ask. This also helps to determine the right wood thickness and screw size.
In summary: stronger back panels, screw connections instead of just plugs, bracing, and fixing to floor/ceiling. This should effectively eliminate any looseness.
SETHBLA
6 Sep 2024 08:29
Reinforcing back panels, securing shelves with screws, and providing additional support significantly improve stability in everyday use.
warrenka57
6 Sep 2024 09:02
I completely understand how frustrating it is to look forward to a modular wardrobe and then find it wobbly. I experienced the same and kept wondering whether this was normal or if I was doing something wrong. By now, what helps me most is adding intermediate supports with brackets and secure anchoring – and honestly, it also reduces some worry because the items need to be safely supported.
Maybe it will help you to check the load capacity per compartment and avoid overloading. That reassured me because I thought, “If I don’t overload the shelf, it will stay stable.” A bit of concern about weight capacity is normal when you don’t have a solid built-in closet.
Dilen
6 Sep 2024 11:11
Hello velina,
to address the issue of looseness in a KALLAX wardrobe in a technically sound way, it’s important to understand the basic construction of the system. KALLAX is made of simple joined particleboard panels, which rely on the back panel and interlocking joints for stability.
The main issue is that the standard back panel is very thin and usually only attached with small nails. Because of this, essential lateral and torsional stiffness is missing. I recommend the following step-by-step approach:
1. Remove the original back panel.
2. Measure the exact external dimensions of the back side.
3. Purchase a 6 mm MDF board or plywood of the same size.
4. Attach the new back panel evenly with at least 10-12 short particleboard screws. You can use small spacers, such as washers, to ensure the panel lies flat.
5. To further reinforce the connection between individual compartments, I recommend using shelf supports with screws and, if needed, additional connection screws through the side panels.
6. If the wardrobe is freestanding, it should be secured at both the floor and the top edge (for example, to the ceiling or a wall). Simple L-brackets with screws are sufficient for this.
Regarding the issue of looseness:
- The reason for this behavior is the thin carcass and the lack of additional lateral rigidity.
- Avoid using self-adhesive back panels, as they hardly improve stability.
One question for you: What is the expected load? Is the wardrobe truly free-hanging, or is it placed in a corner? Have you already installed accessories like clothes rails? This significantly affects how the load is distributed.
By following these measures, you should achieve a notable improvement. Feel free to ask if you have further questions.
benon
6 Sep 2024 12:46
I did something similar last year and can confirm that KALLAX itself is quite flexible – which is not ideal for carrying heavy loads. I completely replaced the back panels with sturdy wooden boards, as Nabla64 already suggested. Additionally, I installed small aluminum brackets in the top corners for reinforcement, fastened on the back of the top row of shelves and on the sides. This provides really good support.
My wardrobe is placed against a wall, but I can imagine that for freestanding structures, it’s best to secure them to the floor and ceiling. Otherwise, just avoid overloading the whole thing and especially be flexible with the clothes rods on the left and right to distribute the load.
Important: Make sure not to use screws that are too short; otherwise, they won’t hold effectively.
Good luck with your project!
