Created on: 16 May 2021 18:56
Acof1978
- Exterior lighting
Floor plan attached.
Grundriss eines Hauses: Wohnzimmer, Küche, Schlaf-/Kinderzimmer, Bad, Flur, Terrasse.
K1300S1 Oct 2021 07:47
motorradsilke schrieb:
Hopefully that is the exception in your case.
Certainly not. We currently have an irregularly shaped corner lot. At the start of construction, there was exactly one official boundary marker (out of more than 20 boundary points registered in the land registry). Since then, there are now two, but the rest were simply never set. The new lot is somewhat less irregular, but so far I have only found one stake that could be a boundary marker. I have no idea if I was just unlucky, but maybe @Escroda can share some insight from his extensive experience.
motorradsilke
1 Oct 2021 08:09
K1300S schrieb:
Certainly not. We currently have an irregularly shaped corner plot. At the start of construction, there was exactly one official boundary marker (out of more than 20 boundary points recorded in the land registry). Now there are two, but the rest were simply never installed. The new plot is somewhat less irregular, but so far I have only found one stake that could be a boundary marker. No idea if I was just unlucky, but maybe @Escroda can share some insights from his extensive experience.
That would be interesting. Our surveyors said they need to install markers if there aren’t enough. How else would they measure the plot?
K1300S1 Oct 2021 08:12
For measuring the plot, no (permanent) boundary markers are needed. Usually, a stake is driven into the ground or marked with paint, but of course, this can easily disappear again, for example, due to an excavator, a neighbor’s dog, and so on. The prices mentioned above refer only to marking with a stake or similar. If you want to have an actual boundary stone installed, it will be more expensive.
1 Oct 2021 09:28
Tom1978 schrieb:
I will probably start with wooden stakes
That’s all we had too. Notably from the surveyors. They have since rotted away. There are no boundary markers.
motorradsilke
1 Oct 2021 09:36
That was all we had as well. Keep in mind, this comes from the surveyors. They have since deteriorated. There are no boundary markers.
What reference point do the surveyors use then? They need at least some boundary marker nearby as a starting point.
K1300S1 Oct 2021 09:40
No, they haven’t needed that for a long time. They carry their GPS device, which allows them to accurately locate the points recorded in the land registry.
