Created on: 16 May 2021 18:56
Acof1978
- Exterior lighting
Floor plan attached.
- Exterior lighting
Tom1978 schrieb:
A question about the surveyor. Why don’t you include a yell4Fachmann in your question—how is @Escroda supposed to know that his type is required?
Rumbi441 schrieb:
Depending on the type of property, you might be able to do that yourself? Measuring X meters away from a fixed point. Once the house is built, the land registry office will come anyway and conduct a survey. This is about tree removal. One side (to the left) is still forest, just like our property. There is no clear boundary there. The tree removal service wants to know how far the property extends.
What does it mean that the land registry office will come? Can you explain that in more detail? :-)
When your house is built, someone from the authorities comes to survey your house on the property and gets paid for it. Sometimes it’s called the land registry office, sometimes the cadastral office or surveying office—you name it. The data can then be viewed later or is available online.
I still don’t understand your problem. Your plot is forest. OK. So most of it has to be cleared anyway? It should be enough if you say, within a meter (3 feet), this part can be cut down and the rest stays standing. I would save the money for an external surveyor.
Rumbi441 schrieb:
When your house is built, someone from the local authority comes out to survey your house and mark it on the property, and they get paid for that. Sometimes it’s called the cadastral office, sometimes the surveyor’s office, you name it. You can then access this data later, and it’s often available online.
I still don’t understand your problem. Your plot is forest. OK. So most of it has to be cleared anyway, right? It should be enough for you to specify the exact meter up to which he can cut, and the rest remains standing. I would save the money for an external surveyor. Can I also get the boundaries marked by the surveying/cadastral office for the later construction of a fence?
