ᐅ Close the gap to the wall with a panel beside the dishwasher
Created on: 10 Mar 2025 11:43
Jampes74
I hope I’m in the right place here. I bought a kitchen in modules. The problem is the clear width and the connections.
The clear width is 2.68 m (8 feet 9.5 inches). With the existing connections, I can only arrange the units in the following order (left to right):
Dishwasher 60 cm (24 inches), base cabinet WAAs 50 cm (20 inches), stove 60 cm (24 inches), base cabinet 90 cm (35 inches). The total is 260 cm (8 feet 6.5 inches).
My problem or question is how to best close the gap between the dishwasher and the wall (about 8 cm (3 inches)).
It needs to be fixed in place and covered.
How should I do this so it looks reasonably good?
Thanks for any tips.
U
user-d29
10 Mar 2025 16:22
kbt09 schrieb:
You definitely need to fasten the countertop separately to the wall, since it shouldn’t rest on the dishwasher.
In fact, the dishwasher is adjusted in height so that the countertop does rest on it. It is practically wedged in place (alongside the screws that will be attached later on the right and left to the kitchen cabinets).
I would install the dishwasher completely according to the instructions. First, attach a wooden batten to the wall (secured with brackets). This prevents the dishwasher from moving sideways. Of course, this must be done with millimeter precision for a tight fit. Then, as mentioned, cover the gap with a front panel – that is, fix a strip both on the wall side and on the dishwasher side (this should be possible using the screws that would otherwise go into the adjacent cabinet carcass). Then glue the front panel onto this.
10 Mar 2025 16:32
Musketier schrieb:
If it isn’t, it may shift when opening or closing, or possibly tilt forward when pulling the basket out if it’s not properly clamped to the countertop.
That makes sense.
nordanney schrieb:
I would install the dishwasher completely according to the instructions. First, attach a wooden batten to the wall (using brackets). That way, the dishwasher can’t move sideways anymore. Of course, it has to be done with millimeter precision for a tight fit. Then, as mentioned, use a front panel to cover the gap—so attach a strip both to the wall side and to the dishwasher side (this should be possible through the screws that would otherwise go into the adjacent cabinet). Then glue the front panel onto that.
Exactly. Attach a wooden batten for the countertop to the wall with brackets; this allows you to at least glue the trim panel at the top. At the bottom, you can also press-fit a wooden batten, so place it on the floor. If there is a baseboard there, the batten will need to be narrower.
kbt09
10 Mar 2025 16:32
nordanney schrieb:
Actually, the dishwasher is adjusted so high that the countertop rests on it.
Yes, the dishwasher base is adjusted to be quite high. However, the dishwasher base is not meant to fully support the countertop; instead, the countertop must be secured to the wall using brackets or a support strip. There is enough space for this. This way, the dishwasher base can be pulled out for repairs and then pushed back in again.
U
user-d29
10 Mar 2025 16:37
No. I meant the other way around. The countertop is "pinching" the dishwasher in.
I have honestly never seen a countertop being fixed to the wall anywhere before. Whether in an inexpensive or a very expensive kitchen, the countertop has always just rested on the cabinets, or the cabinets were screwed to the countertop from underneath (if made of wood; with granite or similar materials, this is not applicable).
kbt09
10 Mar 2025 17:36
@nordanney ... Just trust me, you don’t end a countertop at the end of a run without securing it to the wall or finishing it with an end panel above a dishwasher. That would not be a proper installation.
10 Mar 2025 17:45
nordanney schrieb:
I have actually never seen a countertop being fastened directly to the wall. Whether in a budget or a very expensive kitchen.
This isn’t about a fitted kitchen, but rather a DIY method to secure a floating countertop on the left side. We actually have this setup in the utility room: the countertop “hangs” at the end because a small freestanding refrigerator is pushed underneath. This refrigerator serves as the end of a small kitchen unit. So, a piece of wood is mounted on the wall as a support (instead of a cabinet) to hold up the countertop. If I remember correctly, we did the same in our previous house with a countertop extension (without a cabinet underneath).
