Hello everyone, I am considering using the Ikea Platsa system in my covered garden area and wonder: Is it possible to use Ikea Platsa outdoors, for example on a terrace or in a conservatory, without the furniture deteriorating too quickly? It would be helpful to know how durable the materials used are against moisture, UV exposure, or temperature fluctuations. I am also interested in any practical tips for making the furniture more weather-resistant, if anyone has experience with this. Thanks in advance!
I can understand why this is important to you, @Jenspu. Platsa looks great and is very practical in terms of size, but outdoors… it can quickly feel out of place. I once tried a similar experiment with another Ikea system and soon realized that even with protective films and coatings, the effort required and the risk of stains were too high. If the area is not completely dry, the material will deteriorate over time. It might be worth considering choosing a different piece of furniture that is truly made for outdoor use, even if that changes the overall look a bit.
I agree with you, JAFUHAU. Especially when you have temperature fluctuations, moisture can pass through the pores. The furniture can then swell, causing the wood to expand. The only solution might be regular repainting and monitoring. It is a continuous task and certainly not suitable for someone who wants to use the furniture without much care.
For clarification: Ikea Platsa is explicitly classified as indoor furniture. The chipboard panels and coatings used are not designed to withstand moisture or UV exposure, which can lead to technical damage and changes in appearance. Permanent outdoor use, even in partially covered areas, is not structurally intended. Alternatively, garden furniture made from weather-resistant materials (e.g., aluminum, teak, or plastic) is better suited. If you still choose to use Platsa outdoors, be sure to apply additional weather protection regularly, but note that this does not guarantee protection against damage.
I think the idea of using Platsa outdoors is really cool – no question! 😊 You might consider experimenting with plastic panels and seals on the back to protect the furniture backs from moisture. Maybe plexiglass or something similar as side protection? It might not look as polished as indoors, but it would increase the protection! This will certainly require some effort, but who knows, it could create a really unique look. 😎
I agree with the previous opinions: Platsa is not suitable for outdoor use. If you are looking for a weather-resistant solution, outdoor furniture is the safest choice, even if it looks different. However, you can use the modules outside during dry seasons and bring them indoors in winter, so at least you can enjoy them during the summer.
Thank you for your honest and informative opinions! To summarize: Platsa is generally not suitable for outdoor use, as the chipboard quickly deteriorates from moisture, and UV rays are also an issue. Solutions involving varnishes, protective films, and additional treatments are possible but require a lot of maintenance and regular reapplication. For me, this probably means I should look into other options for outdoor use. Still interesting that some of you are experimenting with creative DIY approaches— I might consider it for a well-protected sunroom.
