ᐅ Is it possible to use Ikea Platsa units outdoors?
Created on: 4 Feb 2022 09:12
Jenspu
Jenspu
4 Feb 2022 09:12
Hello everyone, I am considering using the Ikea Platsa system in my covered garden area and wonder: Is it possible to use Ikea Platsa outdoors, for example on a terrace or in a conservatory, without the furniture deteriorating too quickly? It would be helpful to know how durable the materials used are against moisture, UV exposure, or temperature fluctuations. I am also interested in any practical tips for making the furniture more weather-resistant, if anyone has experience with this. Thanks in advance!
Joshbe
4 Feb 2022 09:45
Basically, the Ikea Platsa system is not designed for outdoor use. The furniture is mostly made of particleboard and melamine coatings, which do not handle moisture or prolonged exposure to water well. Additionally, the materials are not UV-resistant, which can cause fading or deterioration of the surface. If you want to use Platsa in a covered area protected from rain, it might be possible – but there should be no direct contact with water. Regular inspection and maintenance would then be necessary.
GAGRAHAM
4 Feb 2022 10:03
Oh, that sounds exciting! I love Ikea Platsa and think the modules are really flexible! 😍 But outdoors is a completely different story. If you still want to try it, you could consider protecting the furniture with suitable weatherproof covers or paints! That way, you can definitely extend the lifespan. I would just recommend being brave and experimenting, especially if the area is covered and exposed to little rain!
Mufato
4 Feb 2022 10:12
Spontaneously: Platsa is designed for indoor use. Moisture damages the panels. If used outdoors, they must be fully protected and not allowed to get wet continuously.
Jenspu
4 Feb 2022 11:00
Thank you for the quick responses! @Joshbe you described it well, especially the particle boards worry me. @GAGRAHAM which protective coatings or films are you referring to exactly? Maybe a DIY weatherproof solution could work? I want to place it in a partially covered area on the terrace with one open side, where the weather is rather variable with wind and occasional rain. That’s why I’m unsure if it makes sense in the long term.
Joshbe
4 Feb 2022 11:45
[@Jenspu, post: l7j9a8, member: XXX]
Which protective varnishes or films exactly do you mean?
I recommend products based on polyurethane or acrylic that are specifically designed for exterior wood protection. Clear, water-repellent varnishes that also provide UV protection are useful. It is important to sand and clean the surface thoroughly beforehand to ensure proper adhesion of the protective layer. Moisture can still penetrate through the edges of the panels, so these need to be treated or sealed carefully. For films, you can use PVC or weather-resistant specialty films that include UV protection. This protects against water but not necessarily against temperature fluctuations.
