ᐅ How can I protect IKEA PLATSA from moisture in the bathroom?
Created on: 6 Nov 2020 08:34
Mukeo
Hello everyone, I am planning to use the IKEA Platsa system in my bathroom, but I have concerns about the typical moisture levels there. The furniture is basically designed for dry indoor areas, and although my bathroom is well ventilated, the humidity still increases noticeably during showers. My question is: How can I best protect the IKEA Platsa system from moisture in the bathroom so that it lasts as long as possible and avoids damage such as swelling or mold? Are there any special additional measures, surface treatments, or installation tips to consider to make the Platsa system suitable for more humid environments? Thanks for your advice!
Luke44
6 Nov 2020 14:02
Alternative: You could also consider display cabinet doors with glass fronts. They offer better protection against moisture inside but are naturally more expensive.
SAWYERR
7 Nov 2020 08:47
If you want to use the Platsa system in the bathroom, I recommend installing additional covers and baseboards to protect against splashing water. Applying sealing lacquers to the joints also helps. It is important to avoid direct contact with water.
JORDON
7 Nov 2020 10:29
Mukeo schrieb:
How can I best protect the IKEA PLATSA system from moisture in the bathroom, so that it lasts as long as possible and avoids damage like swelling or mold?
Hey, great question! If you want to use PLATSA in the bathroom, become a wood lover who takes good care of their furniture: they need maintenance! 🌿
- Avoid splashes of water!
- Paint the edges, just like you would do a manicure 🖌️
- Always ventilate well after showering (open the window, seriously!)
And if you have time, treat it with a waterproof primer that protects like a rain jacket. That way your PLATSA stays fresh and good-looking even in humid air.
Mukeo
8 Nov 2020 07:21
minan schrieb:
Careful sealing of the cut edges is important, as these areas have the highest water absorption.
Thank you for the detailed explanation! Could you also tell me if there are any specific points to watch out for during installation? For example, screws or fasteners that could cause issues if moisture gets into the wood? And does fully covering the back panels with a vapor barrier really help to minimize the risk of moisture intrusion?
minan
8 Nov 2020 08:05
Mukeo schrieb:
Can you tell me if there are any special points I should watch out for during installation?
Yes, definitely. Screw holes and drillings are potential weak spots. Make sure to treat them with a wood preservative primer before installation and then seal all screw heads with paint or silicone afterwards to prevent water ingress.
Mukeo schrieb:
Does it help to cover the back panels completely with foil to really minimize the risk of moisture penetration?
That can help, but the foil should be breathable to avoid trapping moisture. If you use foil, regularly check that no moisture is trapped behind it – this is often underestimated and can lead to damage.
julian36
9 Nov 2020 11:38
That is a useful suggestion. Glass fronts are significantly more resistant to moisture than wood-based panels or particleboard. A combination of sealed particleboard and glass fronts greatly extends the lifespan of furniture in damp areas. However, it is important to regularly check the seals around the glass frames to prevent water ingress.
