ᐅ How can I protect IKEA Platsa furniture for outdoor use?
Created on: 25 Apr 2024 18:37
Ashkanron
Ashkanron
25 Apr 2024 18:37
I am planning to use IKEA Platsa furniture on my balcony, which is partly covered but not fully protected from the weather. Since the Platsa series is mainly designed for indoor use, I would like to know the best ways to protect this furniture for outdoor conditions, in order to prevent damage from moisture, UV exposure, or temperature fluctuations. Are there specific paints, sealants, or other protective measures you would recommend to extend the furniture’s lifespan? I look forward to your tips, experiences, or warnings if this idea might not be advisable in general.
ju_ren
25 Apr 2024 19:02
I would recommend a clear wood or furniture sealant that repels moisture and provides UV protection. Additionally, be sure not to place the furniture directly on the floor; use feet or legs instead.
klo61
25 Apr 2024 19:26
Hello, I understand that you want to use Platsa furniture outdoors. The most important factor is the type of surface: Platsa is usually made from wood-based panels with a melamine coating, which is not suitable for moisture. To protect it, I would recommend following these steps:
- Clean and degrease the furniture thoroughly
- Apply a single-component clear sealant, such as a suitable acrylic or polyurethane varnish
- Use a UV-resistant varnish to prevent the material from fading
- Prefer shaded or drier areas
Additionally, impregnated protective covers are useful when the furniture is not in use. However, this does not replace surface treatment. Hope this helps a bit.
andre3
26 Apr 2024 07:18
As a supplement: Platsa furniture is made of particleboard with melamine foil, making it highly sensitive to moisture. These materials are not suitable for outdoor use, as water causes the particleboard to swell. If you still want to use the furniture outdoors, please proceed as follows:
- Seal all edges with waterproof silicone
- Sand the melamine surface and seal it with two or three coats of an outdoor-grade clear varnish
- Regularly inspect and repair any damage immediately
Please note that this procedure requires maintenance and will alter the character of the furniture. Alternatively, I would recommend furniture specifically designed for outdoor use.
KLO-KA
26 Apr 2024 08:54
Always place furniture on legs or base plates to prevent direct moisture absorption from the floor. Otherwise, sealing alone is not very effective.
likuken
26 Apr 2024 10:03
I find the idea of using Platsa furniture outdoors quite interesting. The furniture simply isn’t designed for that purpose. So why invest energy and effort into repurposing a product that is doomed to fail in this context?
Andre3 schrieb:
Platsa furniture is made of particleboard with melamine foil, making it extremely sensitive to moisture.
This is exactly what I mean: moisture is the key issue that makes the whole idea pretty pointless. Why not just invest in higher-quality garden furniture that is made to withstand such conditions?
I see this as an attempt to temporarily salvage something that will cause problems in the long run.
