ᐅ Billy shelf unit with a custom-made door: How compatible are they?
Created on: 6 Jul 2023 08:37
MUEIVIND43
I am planning to install a custom-made door on my Billy shelf unit but have some questions regarding compatibility. The original doors fit perfectly and come with specific guide rails and hinges designed especially for Billy. My question is how well a custom door would connect to the existing attachment points on the unit and whether there are any known issues or modifications I should consider.
Also, what about the weight and stability of a self-made door? Could the shelf be negatively affected, or could the hinges be overstrained? I plan to build the door from a reasonably solid wood but am uncertain about the exact dimensions and fastening methods.
Has anyone gained experience with this or can offer advice on what to watch for regarding compatibility? Thanks in advance!
TAUFA
6 Jul 2023 13:03
If you use different hinges, you will need to adjust the door and the shelf accordingly. The original holes are always the easiest option. For heavier doors, cup hinges with a high load capacity rating are more suitable. Look for hinges with a high load-bearing capacity.
nonpra
6 Jul 2023 14:29
Regarding the weight: Original Billy doors weigh about 3–4 kg (6.6–8.8 lbs). If your wood is significantly heavier, you can still use sturdy concealed hinges, but the sides of the shelving unit must be able to support the additional load.
If possible, I would recommend making the door slightly thinner to reduce the weight.
MUEIVIND43
7 Jul 2023 07:57
Thank you for the responses so far; they have already clarified a lot!
I measured again yesterday: My self-made door would probably be made of 1.8 cm (0.7 inch) thick solid wood, weighing around 6-7 kg (13-15 lbs). This is clearly much heavier than the original doors.
Therefore, I am now considering whether to use the original fastenings or switch to other hinges, such as concealed hinges with reinforced load capacity.
How does this affect the structural integrity of the Billy shelf? Could the shelf be damaged due to the increased weight? Or is the frame not really the issue, but rather, as you say,
TAUFA schrieb:
the sides of the shelf also need to bear the load
TRADI
7 Jul 2023 09:13
The sides of the Billy shelves are made of particleboard and are relatively thin. A higher door weight can cause indentations or slight warping over time, especially if you use the door frequently.
This doesn’t mean the shelf will break immediately, but with such a weight, you should try to distribute the load as evenly as possible, for example by using multiple hinges or even an additional support.
The hinges should also be appropriately sized. If you use concealed hinges, choose high-quality models that specify higher load capacities.
As an alternative, you might consider frame door constructions with thinner panels and lightweight design, which helps reduce the weight.
jeix9
7 Jul 2023 11:44
The most important points are: drill the holes precisely, choose the right hinges, and avoid making the door too heavy.
If you keep these in mind, there’s no reason not to make your own door. Shelves suffer less under the load as long as you don’t leave the door open all the time.
Wesley
7 Jul 2023 15:21
Just a quick tip: If you plan to hang the door and are concerned about the weight, you can attach small felt pads or insulation strips where the door meets the shelf. This reduces the load slightly and prevents annoying creaking.
By the way, a solid wood door on a Billy shelf looks really cool! 🙂
Just enjoy it, the project will be fun!
