ᐅ Replacing Billy Regal Shelves with Glass – Is It Possible?
Created on: 20 Mar 2017 18:23
Heinrichna
Hello everyone, I have an Ikea Billy shelf and am considering replacing the standard wooden shelves with glass shelves. My specific question is: Is it technically and practically possible to swap the wooden shelves of the Billy unit for glass shelves without compromising the stability and safety of the shelf? Are any modifications needed to securely fix the glass shelves, and are there any recommended solutions or experiences? I look forward to your advice!
PULAU
21 Mar 2017 12:37
It should also be considered that glass is heavier than wood, which increases the load on the shelf. I recommend checking the maximum load capacity of each glass shelf and the entire shelving unit. Thin glass can break easily; thick safety glass is more expensive but safer.
Tommy38
21 Mar 2017 14:02
Hello Heinrichna, I have done this myself before. It is important to use appropriate glass inserts on the glass shelves that act as shelf liners, so the glass does not rest directly on the metal brackets or wooden strips. This helps distribute the pressure evenly and extends the lifespan of the glass. I also recommend safety glass (tempered glass).
Gino38 schrieb:
The hole spacing for the support strips usually does not fit glass.
That is true, which is why I also replace the brackets.
If you like, I can send you a detailed list with measurements.
Tobias
21 Mar 2017 15:12
Of course, glass shelves are possible, but they are not plug-and-play. It’s best to take the exact dimensions of the original shelf compartment and consult a glass manufacturer.
Heinrichna
21 Mar 2017 16:27
Thanks in advance for the answers! Two points interest me in particular: First, how exactly do you replace the brackets? Are there suitable spare parts available from Ikea, or do you use other systems? And second, how much space should there be between the glass and the shelving unit if no adjustments can be made? I want to avoid the glass touching the sides and ideally have it securely fixed.
Rosan
21 Mar 2017 17:43
Heinrichna schrieb:
How exactly do you replace the brackets?
Ikea doesn’t offer anything special for this. I simply used stainless steel brackets with rubber pads and utilized the existing holes, which holds the glass shelves surprisingly well.
DUUS32
22 Mar 2017 09:58
Regarding your second point: A small gap of about 2-3 mm (0.08-0.12 inches) from the shelf wall is ideal to prevent the glass from rubbing or cracking due to shrinkage or slight movements. Many use small plastic or felt strips as spacers. It is important that the glass is securely positioned and does not wobble.
