ᐅ IKEA Besta: How do I build a combination with glass shelves?
Created on: 17 Feb 2024 09:13
Jamaalpe
Jamaalpe
17 Feb 2024 09:13
Hello everyone, I’m planning to build an IKEA Besta unit with glass shelves and wanted to ask for tips here in the forum on the best way to approach this. Specifically, I want to integrate both closed and open glass shelving elements to create storage space while also achieving an airy look. I’m particularly interested in
- which fittings are best suited for the glass shelves
- how to optimally align and stabilize the glass shelves
- whether there are certain Besta module combinations that work better
- and any special considerations during installation, especially regarding load-bearing capacity
Looking forward to any advice from your experience – maybe someone has a building guide or proven method? Thanks in advance!
neoren
17 Feb 2024 09:46
Glass shelves for Besta are best used with the supplied glass shelf supports that clip into place. The load capacity is limited, so do not place heavy items on them. Simply hang the supports at the desired height into the holes and place the glass shelves on top.
nubar
17 Feb 2024 11:05
Additional to fastening: For greater stability, I recommend not only securing the glass shelves with the clip holders but also placing small rubber pads underneath. These prevent slipping and absorb shocks. It is also important to not exceed the maximum load of 8 kg (17.6 lbs) per glass shelf to ensure safety. Another tip: If the Besta combination is placed against the wall, be sure to use the supplied wall anchors – this significantly improves stability.
KNUTGI
17 Feb 2024 11:28
My recommendation: Combine the glass shelves with the closed Besta doors to create a nice contrast – it looks light and modern. When setting it up, keep the glassware in mind: avoid too much weight and rearrange more often. And hey, if you also experiment a bit with LEDs, you can beautifully highlight the glass shelves! 😉
Jamaalpe
17 Feb 2024 13:42
Thanks in advance, neoren, nubar, and KNUTGI, this is very helpful! The tips about the rubber buffers and wall fixtures are especially important. I was also considering whether to go with the clear glass shelves from IKEA or if tinted glass might better match my interior design concept – does anyone have experience with this?
Also: How is the installation if, for example, I assemble a combination of different heights one after another? Is it better to have several people for this, or can it be done alone? Which tools are essential for assembling the glass components?
Nathanaelk
17 Feb 2024 14:57
About glass selection: Original glass panels from IKEA are clear and relatively lightweight; tinted or frosted glass is not available as standard shelves, so you would need to have custom ones made – in that case, the thickness and edge finish must precisely match the brackets. A technical tip: check the flatness of the shelves with a spirit level; even slight misalignments can cause stress in the glass that could lead to damage.
Regarding assembly: It is definitely recommended to work with at least two people. Glass shelves are slippery and fragile, so precision is essential when installing them. Tools: A cordless drill is great for the basic assembly of the cabinet units and wall mounting, and a small rubber mallet helps with inserting the brackets. Please make sure the drill holes for the wall brackets align properly with your wall – use suitable anchors depending on the wall type! Overall, it’s not complicated, but carefulness is necessary.
