Created on: 11 Sep 2018 07:32
rick2018
Now a bit about me:
Greetings from Swabia
Now a bit about me:
Ah yes, we won’t have a lawn, but the usual greenery instead.
If the mats are that expensive, I’ll take a look at other options. As I said, there is no budget for it at the moment, but eventually the garage roof is planned to be greened. We were told the EPDM membrane functions as a root barrier – it’s already installed.
21°C (70°F) is a nice swimming temperature; do you have a cover mat that can also protect the water from cooling down?
Green roofs usually consist of more than just a root barrier with substrate and seeds on top.
It’s better to wait a bit longer and save up, as it’s unfortunately not very cheap.
Gravel is commonly used as a non-vegetated layer, but other types of stones or tiles can also work.
For the pool, we have a polycarbonate cover with a solar function, although it has not been installed yet.
This cover floats on the water surface (which is necessary because it’s an infinity pool). If someone accidentally steps on it, they only get wet feet but won’t fall through.
The cover helps increase warming during the day and reduces cooling at night.
The pool is also insulated on the sides and bottom.
For us, it was done at the end of April – using a sedum mix.
They need some time to take root, and when cold autumn winds blow, half of it can get blown away. If it gets too cold before they establish, the plants can also freeze.
But be careful: unfortunately, it wasn’t actually a mix in our case. By "mix," I mean different varieties, but it was only one variety in the end. I then planted a few different sedum species myself in between to avoid it looking too monotonous.
The garage roof is about 60m² (645 sq ft). I would have to check the price again, but your figure seems rather expensive to me.
