Created on: 11 Sep 2018 07:32
rick2018
Now a bit about me:
Greetings from Swabia
Modern villa with flat roofs, terraces, glass surfaces, green surroundings – several views.
rick201822 Sep 2020 11:51
Yes, exactly. Most stainless steel pools have a slightly textured surface to provide better grip. They also offer nice reflections.
Mycraft22 Sep 2020 11:52
Looks very good. Top quality!
bortel
22 Sep 2020 12:35
Final stage, absolutely the final stage, you really did everything right, it looks fantastic!!!
Climbee22 Sep 2020 13:24
I also think the little green squeaky duck is cute!!!
How are you handling the green roof? That's still undecided for us as well (but due to budget constraints, it’s being postponed for a few years). We were advised that it’s better to do it in spring rather than autumn. However, the suggestion we received was to use pre-grown mats (they apparently look like egg cartons and already contain the substrate and the appropriate seeds).
So I’m curious how you are doing it.
How warm is the pool by now?
11ant22 Sep 2020 13:42
rick2018 schrieb:
Yes, exactly. Most stainless steel pools have a slightly textured surface for better grip.
They also create beautiful reflections.
Yes, but I didn’t expect it to reflect so variably that it appears irregularly multicolored.
rick201822 Sep 2020 14:17
The pool is currently not heated and is at just under 21°C (70°F). It will most likely cool down significantly over the next few days.
We have different types of green roofing. As mentioned, we will have grass on the garage roof, which means a much thicker substrate or soil layer is necessary due to the grass. We also have irrigation and a robotic lawn mower there.
The other roofs will have a traditional green roof system. You can look up the typical structure: root barrier, drainage layer, etc. There will be a vegetation-free zone around the edges.
These pre-grown mats are not a bad choice. They are a bit more expensive but require considerably less effort. In our case, everything needs to be transported in by large silo trucks.
