ᐅ Air-to-Water Heat Pump: Current Consumption and Data
Created on: 29 Sep 2020 11:06
Bookstar
Hello!
I'll start.
Heated area 200m2 (2,153 sq ft)
KfW 55 standard
Mechanical ventilation with heat recovery
Current outdoor temperature 6°C (43°F)
Heating energy consumption including hot water 35 kWh
Electricity consumption 9 kWh
COP 3.88
halmi
21 Jan 2021 12:54
Ok, understood.
But I think this is more a job for the factory service. As a first step, I would report a fault and provide them with the .dat file.
Which software version do you have installed?
Alessandro
21 Jan 2021 12:59
The heating technician won’t be able to fix it. I also think it’s best to contact the manufacturer’s customer service.
Due to COVID-19, this can often be done over the phone. You know your system well, so it should also work through your mobile phone.
halmi
21 Jan 2021 13:15
I just did some quick Google research. The missing flow rate is always mentioned when the temperature difference rises too much. Where do we currently stand on that?
Z
Zaba12
21 Jan 2021 13:38
In one screenshot, the flow rate is 1380 l/h (580 gallons per hour), and in the other, it is 1580 l/h (700 gallons per hour). So that’s not the cause either. Last month, I tried many things to reduce the temperature difference, but nothing helped.
It’s not just the temperature difference but also the fluctuations in the return temperature. Because of that, I had a total house energy consumption of 43.5 kWh yesterday. You know what temperatures we had yesterday—between 3-7°C (37-45°F) outside.
I even tried to ignore the temperature difference of 8-9K (8-9°C / 14-16°F) because I thought, “whatever.” But it really costs me money when the heat pump starts again after 45 minutes, even though it ran for 7 hours before, and the floor is noticeably “hot.”
halmi
21 Jan 2021 13:45
Have you roughly calculated the flow rate using the Tacosetters to see if it makes sense? With or without a basement?
Z
Zaba12
21 Jan 2021 13:53
halmi schrieb:
Have you roughly recalculated the flow with the Taco setters to see if that makes sense? With or without a basement?
All values were set and read directly on the Taco setter itself.
- 1380 without basement
- 1560 with basement
Thanks for Googling :-)
