ᐅ Air-to-Water Heat Pump: Current Consumption and Data
Created on: 29 Sep 2020 11:06
Bookstar
Hello!
I'll start.
Heated area 200m2 (2,153 sq ft)
KfW 55 standard
Mechanical ventilation with heat recovery
Current outdoor temperature 6°C (43°F)
Heating energy consumption including hot water 35 kWh
Electricity consumption 9 kWh
COP 3.88
Z
Zaba12
22 Apr 2021 20:15
guckuck2 schrieb:
18,000 kWh for a somewhat modern building is quite a statement. In the 1970s construction, we had 21 m² (approximately 226 sq ft) with 22,000 kWh including a heated conservatory (new gas boiler, radiators).
We have already discussed the topic; Bookstars’ house and location remain a mystery. It’s always cold outside, no solar gains, and the house consumes heat like a black hole.
Bookstar
22 Apr 2021 20:31
guckuck2 schrieb:
18,000 kWh for a somewhat modern building is quite a statement. In a 1970s building with 210 m² (2,260 sq ft), we were at 22,000 kWh including a heated conservatory (new gas boiler, radiators)
Well, that shows what insulation mania brings, namely nothing. Others are not much lower either. But that’s just how it is 🙂
halmi
22 Apr 2021 20:51
Well, we are at 11,500 kWh of heating, solar yield 4.3. Heated area is 218 m² (2,347 ft²).
guckuck2
22 Apr 2021 20:53
Same here, around 11,000 including hot water.
Better to have “insulation craze” than escape from reality.
Bookstar
22 Apr 2021 21:04
halmi schrieb:
Well, we have 11,500 kWh of heat, climate zone 4.3. Heated area is 218m2 (2,346 sq ft).
Okay, I’m about one-third above that. Where does it come from? I have no idea. Everything is standardized, stone and insulation materials. It can only be due to the location and temperatures, etc.…
nordanney
22 Apr 2021 21:31
Hemp plantation inside the house? Then you always need 28°C (82°F). 😉
