ᐅ Single-family house floor plan, 1 full story, utilities and natural lighting
Created on: 22 Jul 2024 08:21
klabauter8614
Hello, I would like to gather feedback on the floor plan in order to finalize the design. We don’t have sections or elevations yet, but all other drawings are attached (house shown schematically on the site plan). Thanks.
Plot size: 473m² (5,089 ft²)
Slope: no
Site coverage ratio: 0.4
Floor area ratio
Edge development
Number of parking spaces: maximum 2 without garage
Number of floors: 1 full floor
Roof type: gable roof
Architectural style
Orientation: Roof facing NNE - SSW
Maximum heights / limits: eave height 4.2m (13.8 ft), ridge height 9.5m (31.2 ft)
Further requirements: only renewable energy sources, infiltration trench for stormwater
Basement, floors: no basement (groundwater level at 1m (3.3 ft) depth), 1 full floor
Number of occupants, ages: 4, aged 40-40-7-2 years
Space needs on ground floor and upper floor: Guesst room on the ground floor, office upstairs
Office use: family use or home office? Home office
Number of guest stays per year: 2 nights per week by one parent (also for coming years), parents-in-law stay several weeks annually
Open or closed layout
Traditional or modern construction
Open kitchen, kitchen island: semi-open (sliding door), kitchen island
Number of fixed dining seats: 6 fixed, expandable
Fireplace: no
Music/speaker wall: no
Garage, carport: garage
Utility garden, greenhouse: herb garden
Additional wishes/special points/daily routine, including reasons for preferences or exclusions
Planner: synergy between architect and client, now 4th draft
What do you particularly like? Why? Guest room and WC + shower, similar existing layout already working (although a bed is drawn, it is actually a sofa bed), office on the north side, guest room size more than sufficient, wardrobe by the entrance, living room bright, washing machine + dryer upstairs.
What don’t you like? Why?
- Utility room is half unusable due to wardrobe protrusion (which is actually sensible) so it is too small. Attic storage needs to be moved from the garage into the thermal envelope inside the utility room, indoor unit could stay there. The mechanical ventilation system would also need to be installed in the utility room. Possible solution: enlarge kitchen to the rear and expand utility room accordingly. This would make the house larger though. No other solutions discussed yet.
- Stairs are too steep; architect now proposes a rise/run of 17.2cm/26cm (6.8"/10.2"), which may be borderline regarding comfortable step depth.
- Daylight in children’s rooms might be low due to west-facing windows and roughly 12.5% window-to-floor area ratio; simulation might be needed. Skylights wouldn’t significantly improve this; only a dormer and smaller gable windows would.
- As drawn, the kitchen island layout is not suitable for me; passage from utility room too narrow, should be moved to the opposite side, with sink and window to the left.
- Air conditioning would still be needed in the bedroom and children’s rooms, but with the current window and furniture arrangement this looks impractical.
- Shower upstairs located under sloped ceiling, not necessary but a minor point.
- Skylight in guest WC is not at head height, should be slightly higher, also a minor detail.
- Bathroom door upstairs should open outwards.
- Storage under the stairs is still missing.
- Partition wall in garage is unnecessary.
Cost estimate from architect/planner: unknown
Personal price limit for house including fixtures: 650,000
Preferred heating technology: air-source heat pump
If you must give up something, which features or extensions
- Can you give up: walk-in closet
- Cannot give up: office, guest room
Why is the design like it is now?
Own design developed based on space requirements plus architect’s counter proposal
What do you consider especially good or problematic?
Main issues to resolve are utility room + technical space and daylight.
Slope: no
Floor area ratio
Edge development
Architectural style
Fireplace: no
klabauter861430 Aug 2024 18:27And the hallway around the ground floor, since I have to make a turn into the living room there
klabauter8614 schrieb:
We spent several hours together going through everything, which was much better than the back-and-forth. This is what came out of it. [...] Although the technical equipment is still marked in the garage, I will need to clarify why at the next appointment.Well, it seems the appointment was still too short. You will have to break down the "technical equipment" box in your mind and in the conversation with the planner, including building entries (as I already mentioned, these must not be built over) and components (which require not just space for adjustment but also for operation). The planner probably wants to keep the lines between the "boiler" and the "outdoor unit" short. You must not treat this as a minor issue on the side.https://www.instagram.com/11antgmxde/
klabauter861430 Aug 2024 21:13No idea how that is supposed to work. Multi-utility entry into the utility room and then a transfer point, and then from the internal house circuit, insulated pipes plus electricity again under the slab into the garage or something? Mysterious.
I would rather see how all those things fit into the utility room.
We spent several hours together. . And the result is @K a t j a’s idea from #39.K
klabauter861430 Aug 2024 22:31hanse987 schrieb:
If you bring the technical installations into the house, then you could also build a garage without insulation, since it is now part of the thermal envelope. Exactly, now it is frost-free, but I don’t want to heat it, and otherwise it wouldn’t need insulation. That’s probably something to discuss.
. . And the result was @K a t j a’s idea from #39. Yeah, somehow, that could be a positive sign. Even the door to the boiler room seems to fit. Although the entrance area somehow doesn’t look quite right, it seems a bit ‘crooked’?
