ᐅ Who has experience using wooden storage boxes in Kallax shelves?
Created on: 17 Jun 2024 14:37
allessandr
allessandr
17 Jun 2024 14:37
I am currently considering complementing my IKEA Kallax shelves with matching wooden storage boxes. I am mainly looking for more stable and visually higher-quality storage solutions than the usual fabric boxes. My question to the community: Who has experience with wooden storage boxes specifically designed for or fitting Kallax shelves? How do they perform in terms of exact fit, craftsmanship, and handling (e.g., inserting and removing)?
I want to avoid boxes that are too tight or difficult to move. Additionally, I’m interested in whether these wooden boxes are a practical alternative in terms of durability and aesthetics. Perhaps someone has already tried different suppliers or can offer tips on wood type, weight, or maximum load capacity.
I look forward to your detailed experiences and recommendations!
benon
17 Jun 2024 15:29
Hello allessandr,
I can relate well to your question, as I have been using wooden boxes as inserts in my Kallax shelving unit for about two years. Here are my experiences:
Fit is indeed a major issue. Most wooden boxes I found are either custom-made or come in standard sizes, so it’s essential to carefully compare their dimensions with the internal measurements of the Kallax before purchasing. Some manufacturers offer a tolerance of +/- 2 mm, which is often a good guideline.
Regarding craftsmanship: I use boxes made of beech wood, which are very sturdy yet not too heavy. The surface is usually oiled or waxed, improving grip and increasing durability.
Handling is generally good as long as the boxes are precisely made. You can notice the difference when they are too tight – then removing them can be a bit tricky. Slightly rubberized edges or corners can sometimes help prevent this.
About your point on load capacity: the boxes can handle quite a bit – I store technical equipment, books, and even small tools without any issues.
If you like, I can share manufacturers and suppliers that I have personally tested. Feel free to ask if you have any questions!
SETHBLA
17 Jun 2024 18:42
allessandr schrieb:
What about the exact fit, the workmanship, and handling (e.g., inserting and removing)?
Pay close attention to the exact internal dimensions of the Kallax (33x33 cm (13x13 inches) standard). Many users recommend boxes with a maximum size of 32.5x32.5 cm (12.8x12.8 inches) or slightly smaller to avoid the boxes getting stuck.
allessandr schrieb:
Any tips on wood type, weight, or maximum load capacity?
Lightweight woods like poplar or birch plywood work well; they are sturdy and not too heavy. The maximum load capacity is usually around 5–10 kg (11–22 lbs), depending on the construction.
Usually, you don’t need to know much more than that.
Maria35
18 Jun 2024 09:51
benon schrieb:
Fit is actually a major issue. Most wooden boxes I found are either custom-made or come in standardized sizes, which you definitely should compare carefully with the internal dimensions of your Kallax before buying.
This is where a commonly underestimated point comes in: The official dimensions of the IKEA Kallax are based on an internal measurement of 33x33 cm (13x13 inches), but actual sizes can vary slightly due to manufacturing tolerances.
Therefore, it makes sense to measure each individual compartment of your shelving unit before purchasing wooden boxes. Otherwise, you risk choosing boxes that are too tight or don’t fit at all.
In addition, you should consider the type of wood and the craftsmanship in terms of moisture resistance. Especially untreated wood tends to warp if it is placed in rather humid rooms.
I therefore recommend a oiled or lacquered finish, which protects the wood from moisture without completely losing the natural feel.
Regarding load capacity, various manufacturers provide different figures — often ranging between 5 and 12 kg (11 and 26 lbs) per box, depending on the wood’s joinery and base construction.
In summary, investing in high-quality, well-fitting wooden boxes greatly enhances the look, but careful selection is also important.
