ᐅ Which tools do I need for remodeling Ikea Metod kitchen units?
Created on: 21 Apr 2021 09:37
LenojaHello everyone, I am currently planning to renovate an Ikea Metod kitchen unit and have realized that I need to get a good overview of the necessary tools beforehand. My goal is to partially modify the Metod cabinets by, for example, replacing the fronts, adjusting some shelves, and possibly drilling holes for additional built-in elements. Therefore, my specific question to the community is: Which tools are essential for renovating Ikea Metod kitchen units? I am especially interested in tools that can be used both for assembly and modifications. This naturally includes manual tools related to the cabinet materials (chipboard, metal fittings). Many thanks in advance for your tips and experiences!
Hello Lenoja, thank you for your very detailed question! For remodeling IKEA Metod kitchen units, you definitely need a good set of basic tools that will help you both dismantle and modify the components.
The most important tools are:
- A cordless drill with various drill and screwdriver bits. This will allow you to remove screws or drill new holes.
- A set of Phillips and slotted screwdrivers, as many fittings use different types of screws.
- A jigsaw is very useful for making cutouts or adjustments to the wooden panels.
- For fine work and smoothing edges, a set of files or sandpaper should also be on hand.
- A tape measure and a carpenter’s square with multiple angles for precise measuring and marking.
- A rubber mallet or small hammer to gently install fittings without damage.
A set of pliers can be helpful for removing or straightening fittings. And of course, safety glasses and gloves are essential for protection when sawing or drilling. If you plan to drill additional holes for other built-in elements, make sure to use an appropriate drill bit for chipboard panels.
If you want to know in more detail which screwdriver bits IKEA uses for Metod, I’d be happy to explain further.
koneo schrieb:
A cordless drill driver with various drill and screwdriver bits. This allows you to remove screws or drill new holes.Absolutely! The cordless drill driver is your best friend during renovations! I just remodeled my Metod kitchen, and without this tool, it would have taken me forever! The different attachments especially make screwing and drilling so much easier and faster.
I would also recommend having a spirit level handy. Especially when rearranging the kitchen or installing new shelves, it’s really important that everything is perfectly aligned. This gives your renovation a professional finish!
Good luck with your project, it’s really rewarding to design your own living space!
Landontau22 Apr 2021 08:47Hello Lenoja and all readers,
I would like to add to the input from koneo and Pome60 by providing a sort of tool list for the Metod kitchen renovation. Here is a brief guide on which tools are useful for each step of the work.
1. Disassembly:
- Screwdriver set (Phillips and flathead)
- Cordless drill/driver (for loosening screws)
- Rubber mallet (to gently tap fittings loose)
2. Furniture adjustment:
- Jigsaw with a fine-toothed blade (for cutouts or shortening cabinet boxes)
- Drill (wood and metal, depending on the fittings)
- Square and tape measure (for precise measurements)
3. Assembly:
- Cordless drill/driver with bits (make sure to use bits that fit the Metod-specific screws)
- Spirit level (for proper alignment)
- Clamps (can help hold parts in place)
4. Finishing touches:
- Sandpaper/edge sander (for smoothing edges)
- Possibly adhesive or silicone sealant (for sealing)
Potential issue: Be careful not to place new drill holes too close to existing ones, as this can weaken the material. When replacing fronts, check if the attachment methods are identical; otherwise, some adjustments may be required.
Summary: Basic equipment with a cordless drill/driver, screwdrivers, tape measure, jigsaw, and spirit level is essential. Additional special drill bits and finishing work complete the toolkit.
I hope this helps you move forward!
1. Disassembly:
3. Assembly:
I understand that a renovation project can sometimes feel overwhelming. The tools are necessary, but how you use them also makes a big difference.
I can only confirm this from my own experience. I once drilled holes too close together, which caused unpleasant cracks in the chipboard. That not only led to frustration but also extra work for repairs.
My advice: Stay calm – work carefully and measure thoroughly. And if something doesn’t go as planned, that’s okay too; you learn from it.
A renovation is also a creative and personal process, so it’s okay to take your time and allow yourself breaks now and then to avoid losing the joy in it.
Landontau schrieb:
Potential mistake: Be careful not to place new drill holes too close to existing ones, or the material will become unstable.
