ᐅ What tools are needed to adjust Ikea Hemnes wardrobe doors?
Created on: 8 Oct 2022 18:37
O
olesra
O
olesra
8 Oct 2022 18:37
Hello everyone, I have a specific question regarding furniture assembly: Which tools are specifically needed to properly adjust the doors of an Ikea Hemnes wardrobe? It is important to me to align the doors so that they close smoothly and do not hang or sit unevenly. I am familiar with the basic adjustment options on the hinges, but which screwdrivers or other tools are actually required for this? Also, are there any tips to watch out for in order to avoid warping or damage? I look forward to any detailed advice, including brief explanations on the best way to proceed.
Jukin
8 Oct 2022 19:12
Hello olesra, that is a very good and detailed question! For adjusting the Hemnes cabinet doors, you usually only need a Phillips screwdriver (PH2), as the hardware is mostly equipped with Phillips screws. The screws on the hinges can be adjusted as follows:
- The screw for horizontal adjustment (side-to-side)
- The screw for vertical adjustment (height)
- Optionally, the screw for depth adjustment (distance from the cabinet body)
A small screwdriver is usually sufficient, preferably with a sturdy handle for more torque. Some also recommend a magnetic tip to prevent the screws from falling during adjustment. It is important to adjust the doors gradually and check repeatedly whether they close properly. Avoid turning the screws too much to prevent damage to the material. If the doors sag more noticeably, it may help to check the hinges or tighten the mounting screws on the cabinet body if necessary.
PeoDaniel
8 Oct 2022 19:35
I would like to add to Jukin’s comment: In my experience, in addition to a Phillips screwdriver, it’s useful to have a spirit level on hand to better align the doors visually. Especially with larger cabinets, you often only realize with a spirit level whether everything is truly straight.
What is often overlooked is that you should also have pliers or a small hammer ready in case a hinge needs to be adjusted or gently bent – this can happen if the wood is slightly warped or the hinge is already a little loose. Of course, this should be done carefully.
One more tip: If you need to adjust the doors frequently or if they’re stiff, a drop of lubricating oil on the hinges might help. But don’t use too much, or it will get too greasy and attract dust.
glapu
8 Oct 2022 20:01
Brief and to the point: 1. Phillips screwdriver PH2
2. Spirit level (optional)
3. Small pliers (for emergencies)
That's all you need to adjust Hemnes doors.
Ethan
8 Oct 2022 21:18
Hello olesra,
I agree with the previous answers and would like to briefly explain why a Phillips screwdriver PH2 is particularly important: Ikea uses standardized screws for most of their furniture, which are specifically designed for this purpose. A PH2 fits perfectly and prevents the screws from stripping, which can easily happen with the wrong screwdrivers.
Regarding the procedure:
- Loosely attach the door.
- Slightly tighten all screws, identify the three adjustment screws on the hinge.
- First, make the horizontal adjustment (as Jukin already mentioned).
- Then adjust the vertical position.
- Finally, check the depth adjustment.
A spirit level is a very helpful tool but not absolutely necessary. For safe handling, it’s best to take your time and adjust little by little. If you’re unsure, you can mark the edges of the door with a felt-tip pen or some small pieces of tape to better see how the position changes.
todunar
9 Oct 2022 08:47
Hey olesra, great topic! Properly adjusting the Hemnes cabinet doors really makes a huge difference, and having the right tools makes it much easier! A great tip from me: definitely use a screwdriver with a rotating handle – it really simplifies the screwing work.
Also, if you encounter really stubborn screws, a small cordless drill with adjustable torque can help, but use it carefully!
And very important: be patient! I had my struggles at first too, but with a bit of trial and error and the right tools, screwing can even be fun! Good luck, and feel free to share how it goes for you!
