ᐅ Which screwdrivers are best suited for assembling IKEA HEMNES furniture?
Created on: 12 Sep 2021 18:27
draefecanD
draefecan12 Sep 2021 18:27Hello everyone, I am about to assemble an IKEA Hemnes wardrobe and wanted to ask a specific question: Which screwdrivers are best suited for assembling the HEMNES, especially for the typical fasteners and screw heads that IKEA uses?
So far, I only have basic Phillips screwdrivers and a small standard screwdriver, but I’m not sure if these are really the best tools for the screws provided.
I would also appreciate advice on handle comfort, the fit of the screwdriver tips, and whether a cordless drill/driver is helpful or rather a hindrance.
Thank you very much for your recommendations!
draefecan schrieb:
Which screwdrivers are best suited for assembling the HEMNES, especially for the typical fasteners and screw heads that IKEA uses?Hello! For assembling the HEMNES, I generally recommend screwdrivers with Phillips (PH2) and flathead tips. IKEA often uses Euro-flat-head screws for the wooden parts and Phillips screws for the metal connectors.
1. Phillips (PH2): Ideal for most screws in the package. Make sure the tip fits well to avoid slipping out or damaging the screw heads.
2. Flathead: Needed less often but sometimes required for securing dowels.
3. Handle comfort: A rubberized handle with an ergonomic shape makes longer screwing easier.
4. Cordless screwdriver: Recommended if you manage the torque carefully to prevent over-tightening. A screwdriver bit with a depth stop can help.
In summary: A PH2 screwdriver with an ergonomic handle plus a suitable flathead screwdriver covers almost everything. Good luck!
KUDAISY schrieb:
A PH2 screwdriver with an ergonomic handle plus a matching flathead screwdriver covers almost everything.Exactly! And honestly, who wants to mess around with a tiny mini Phillips screwdriver on such a large cabinet? 😄 Ergonomics and good handles are a must, otherwise what should take 30 minutes quickly turns into 2 hours.
A set with multiple bits and a small cordless drill makes the job easier, but beware: avoid using high speed, or you risk stripping the screws. It’s better to work calmly and with care!
AUSTINREN13 Sep 2021 09:14The screws used in IKEA HEMNES furniture are mostly standardized Phillips head screws of size PH2. A suitable screwdriver with a high-quality tip prevents rounding off the screw heads.
Cordless drills are useful, provided the torque setting is correctly adjusted to avoid over-tightening or damaging the wood. For assembly, I recommend:
- PH2 screwdriver with an ergonomic handle
- Screwdriver with a magnetic tip for easier handling
- Cordless drill with torque control (max. 3-4 Nm)
This selection minimizes time spent and damage to the materials.
