ᐅ How can I equip IKEA Metod cabinet doors with magnetic catches?
Created on: 10 May 2023 08:14
Laanmi
Laanmi
10 May 2023 08:14
Hello everyone, I want to equip my IKEA Metod kitchen cabinet doors with magnetic catches and am looking for a practical solution. The cabinet doors currently have the standard hinge closures, which often close reluctantly or lose some of their effectiveness after prolonged use. My specific question is: How can I install magnetic catches on IKEA Metod cabinet doors without affecting the appearance or having to perform complicated modifications? I’m interested in tips on which types of magnetic catches work best, the best way to install them, and what technical aspects I should pay attention to, especially regarding the door thickness and compatibility with the Metod system. Thanks in advance for any helpful advice!
kaubi
10 May 2023 08:43
Hello Laanmi, I’m taking the time to provide a more detailed answer to your question, because with Metod cabinet doors, the material thickness and hinge design are crucial for successfully installing magnetic catches. Basically, there are two main types of magnetic catches for furniture:
- Recessed magnets, which are embedded and hidden inside the door or carcass
- Surface-mounted or screwed-on small magnetic catches, which may be visible from the outside
Metod doors are usually about 16 mm (5/8 inches) thick (particleboard with foil). Here, you can use small neodymium disc magnets that provide enough holding force. Precise positioning is important: the magnet is attached to the inside of the door, and the metal piece (usually a metal plate) is installed inside the carcass. When mounting, you should proceed as follows:
- Choose a position so the magnet does not interfere with the door hinge
- Glue the magnets onto a hard, flat surface, ideally using two-component adhesive or special mounting glue
- Align the metal plate exactly to ensure the magnetic catch snaps shut precisely
One important point, especially if you don’t want to change the appearance: there are flat magnetic catches or even recessed ones that you can rout out with a Forstner bit. However, this requires precise work. As an alternative, many DIY enthusiasts use small, flat rubber adhesive pads with magnets positioned underneath. These hold less strongly but are easy to apply and nearly invisible.
I’m curious whether you are familiar with power tools, as they make precise routing much easier. Also: how tightly do you want the doors to close? Do you want a fully self-closing system, or is a supportive magnetic catch sufficient for you?
KIN42
10 May 2023 09:07
I would like to add that, in addition to the magnetic catches mentioned, there are also special locking systems for Metod cabinets that operate magnetically but are specifically designed to work with the hinges. These systems combine magnetic technology with spring pressure, so the door must overcome a defined resistance to close and then stays securely held by the magnet.
You should also pay attention to the load capacity. Standard magnets can often only reliably hold doors weighing about 2-3 kg (4.5-6.6 lbs). If your doors are heavier, the magnetic force needs to be stronger – however, this may make the door harder to open.
My advice: first accurately measure the weight of the doors and, if possible, test with small neodymium magnets of different strengths. You will find the best position by trying to support the closing angle in the most effective way.
The finish of the door edges also plays a role. Uneven surfaces can make it more difficult for the magnet to hold.
Layla
10 May 2023 09:23
Hello Laanmi, I completely understand that you’re looking for the most elegant solution possible, because there’s nothing more frustrating than doors that don’t close properly or are difficult to close. From my experience with my own Metod cabinet, magnetic catches are a great addition since they not only improve the closing but also provide a smoother, almost high-quality feel when shutting the door.
Maybe you could consider an option like the “invisible” magnetic catches, as they barely stand out. I was initially worried that installation might be complicated, but with a steady hand and a bit of preparation, it’s quite doable. Definitely test on one door first to find the optimal position. And if you decide to recess the catch, this can be done quite cleanly with a simple drill bit.
Regarding the material, I’ve done some research: the magnetic force should be strong enough to hold the door securely when gently pushed, but not so strong that you have to force it open. This is especially practical if you have children or cook often.
floga
10 May 2023 09:45
I can confirm what Layla mentioned. It really is a relief when the doors gain a bit more life with magnets. If you decide to use magnets, my personal tip would be to also consider the type of handle on your doors. Some handles make the door easier to open when pulled, so the magnet doesn’t have to hold the door too firmly.
To add a bit more advice: I would recommend always installing magnets in pairs—not just at the top or bottom, but at least at two points—to distribute the force evenly and ensure the door closes flush. Otherwise, the doors might twist slightly or not latch properly.
By the way, the sound is usually pleasant if you choose the right magnets. Cheap standard magnets can rattle easily.
Jeanbar
10 May 2023 10:11
Welcome Laanmi! Your question is very practical, and I want to tell you that many users generally appreciate magnetic locks on Metod doors. There are different products available for installation:
- "Push-to-open" systems (handleless) with built-in magnetic catches
- Magnetic handles or standard magnetic catches as an addition
If you want to keep the original look, a push-to-open system might be more complicated because you may need to replace the hinges. For magnetic additional locks, I recommend small neodymium magnet sets that you can install yourself. Simply attach them inside the door and on the cabinet frame with adhesive or screws.
One tip: Clean the surfaces thoroughly before installation to ensure the adhesive sticks properly. If you open the doors frequently, make sure there are no ferromagnetic small parts near the magnets, as they could affect the magnetic force.
If you have any further questions about the installation, I’m happy to help!
