ᐅ How can I equip IKEA Metod cabinet doors with magnetic catches?
Created on: 10 May 2023 08:14
Laanmi
Hello everyone, I want to equip my IKEA Metod kitchen cabinet doors with magnetic catches and am looking for a practical solution. The cabinet doors currently have the standard hinge closures, which often close reluctantly or lose some of their effectiveness after prolonged use. My specific question is: How can I install magnetic catches on IKEA Metod cabinet doors without affecting the appearance or having to perform complicated modifications? I’m interested in tips on which types of magnetic catches work best, the best way to install them, and what technical aspects I should pay attention to, especially regarding the door thickness and compatibility with the Metod system. Thanks in advance for any helpful advice!
kaubi schrieb:
Metod doors usually have a thickness of around 16 mm (approximately 5/8 inch) and are made of particleboard with a laminate finish. In this case, small neodymium disc magnets can be used, which provide sufficient holding force.That is exactly right. Additionally, I would suggest paying attention to the hinge itself when positioning the magnets. Some Metod hinges are designed to slightly pull the door inward, which affects the placement of the magnetic catches. Sometimes you need to adjust the position slightly to achieve the optimal closing force.
Also, be aware of whether you have matte or glossy fronts. On glossy surfaces, any adhesive residues are often more noticeable. It is worth either applying adhesive very sparingly or using screws for the metal plate if possible.
Magnetic catches on Metod doors work best with strong neodymium magnets. Glue the magnets to the inside of the door and the metal plates to the cabinet frame. Make sure they are precisely aligned; otherwise, they won’t hold properly. Recessing the magnets is optional but improves the appearance.
I really like the idea of using magnets! It definitely makes closing the doors much more pleasant, giving them a gentle pull.
If you want, you can easily avoid a sharp "click-clack" sound by placing soft rubber pads under the magnets. This also helps to soften the magnetic closure.
And yes, there are these small, invisible magnetic catches that fit neatly and don’t stand out. I hope you have some tools ready! Otherwise, sewing them in is unfortunately not an easy task.
Mufato schrieb:
Stick the magnets inside the door and the metal plates on the cabinet frame.I can only confirm that. For me, it was especially important to choose the right magnets because weak magnets constantly caused problems. I now have magnets that are strong enough to keep the door closed at any normal position, but not so strong that the door is difficult to open.
KIN42 schrieb:
Sometimes you need to adjust the position slightly to achieve the optimal closing force.This is exactly a key point. I also strongly recommend testing with a piece of paper or thin cardboard before the final installation to find the exact spot where the magnet works best. It’s like fine-tuning, similar to adjusting a door that sticks slightly—but in reverse.
Also, a note about adhesive: if you decide to use adhesive magnets, choose one with very high initial tack and low stress to avoid damaging the door material. This is especially important for laminated surfaces, which can otherwise cause problems.
Are you aiming to keep the doors firmly closed, or just wanting a slight pull to keep them shut? This will significantly influence the choice.
Laanmi schrieb:
How can I equip IKEA Metod cabinet doors with magnetic catches without affecting the appearance or having to do complicated modifications?This is a very well-posed question, and I would definitely recommend choosing a system that fits your specific needs. If the appearance is very important to you, surface-mounted, visible magnets are usually not ideal – in that case, slim magnetic catches that can be discreetly attached inside the door are a better option.
If you don’t have a workshop where you can rout into the doors, adhesive or screw-on magnets are the alternatives. Also, make sure that the strength of the magnets matches the weight of your doors. I also have a short installation video or step-by-step guide available if you’re interested. That can be quite helpful.
