Good morning everyone, I am currently facing the challenge of how to install the doors of my IKEA METOD cabinet as perfectly as possible, so that they not only look straight but also close precisely and have no uneven gaps. I have already installed the included hinges, but unfortunately, some doors appear slightly warped or do not sit exactly in place. I suspect that careful adjustment of the hinges is key here, possibly also the correct screwing of the doors to the cabinet frame. Does anyone have experience or tips on how to achieve an optimal fit specifically with METOD doors? Are there special tricks for alignment, hinge adjustment, or door installation that go beyond the basic instructions? I would appreciate very detailed advice, as this topic is more complex for me than I initially thought. Thank you in advance!
Your question about the METOD doors will surely resonate with many who have experienced this issue. I have also often had problems with the hinges because the doors appeared to be warped when delivered. It is important to take your time during installation and, above all, to repeatedly check and readjust all the adjustment screws. Sometimes doors seem crooked, even though the real problem lies with poorly tightened screws. If you like, I can also explain how I managed to get my doors to fit reasonably well.
relupa schrieb:
Sometimes doors appear crooked even though the issue is actually caused by poorly tightened screws. Thanks for the insight, that’s exactly what I was suspecting. If you don’t mind, please share more about your approach to adjusting and installing doors. I’d like to know how you proceed systematically and whether you loosen and retighten all the hinge screws repeatedly until the door fits perfectly. Are there any special tools you recommend for the adjustments or specific details about the hinge mechanics that should be considered? That would be really helpful!
Hello, to perfectly align the METOD doors, I recommend following these steps carefully:
- First, loosely attach the doors to the cabinet frame using the hinges.
- Then, use a spirit level or a ruler to check if the door looks visually straight.
- The METOD hinges have three adjustment screws: one for depth, one for lateral movement, and one for height adjustment.
- Start with the height adjustment to bring the door exactly flush with the cabinet frame.
- Next, adjust the lateral position so that the gaps between adjacent doors or side panels are even.
- Finally, adjust the depth so the door sits flush with the cabinet surface.
- When all adjustments are correct, tighten all screws securely and check the door’s opening and closing again.
A common mistake is to tighten the screws fully before making adjustments, leaving no room to position the door optimally. If you are patient and work through the steps one by one, the result will definitely be better.
jelite schrieb:
A common mistake is overtightening the screws before adjusting I can only confirm that. I often felt like everyone tightened everything 'final' right away, and then the door ended up crooked. Nowadays, I take the time and proceed step by step. Especially when dealing with multiple doors, it’s important to loosely fit them all first and then fine-tune them together like an aircraft formation.
