ᐅ Is it possible to replace the drawer fronts in Ikea Metod cabinets?
Created on: 22 Oct 2023 16:23
DEORAHello everyone,
I am currently planning to upgrade my kitchen using the Ikea Metod system and am wondering if it is possible to replace the drawer fronts without having to change the entire drawer or cabinet frame. Specifically, I want to know if the fronts can be simply removed and swapped for different designs or colors, for example if the old fronts are damaged or if I want to change the style.
Does anyone have experience with this or know if Ikea uses standardized dimensions and fastening methods that make such a replacement straightforward? I imagine it would be possible to order just the fronts as separate parts and change them without much effort.
Thanks for your tips and advice!
I can understand that the idea of just replacing the fronts on the Metod drawers sounds appealing. I have done some minor renovations in my own kitchen and initially found it a bit tricky to figure out exactly what is compatible.
From my experience, I would say that Ikea does offer standardized fronts for the Metod drawers according to the drawer depths, but you need to pay close attention to the type of drawer (e.g., full extension vs. soft-close) and the depth.
Especially when the fronts have integrated handles, you should ensure compatibility; otherwise, they won’t fit aesthetically. For example, I once had to reorder fronts and realized that there are different height and width dimensions.
But basically, it is doable to replace the fronts. As I understand it, the fronts are attached with screws from the inside of the drawer, so you can detach and replace them.
Important: Make sure to pay attention to the exact product number or series; otherwise, it won’t fit.
To answer precisely whether you can replace the drawer fronts in Ikea Metod cabinets: Yes, it is technically possible because Ikea sells the Metod fronts and drawers separately.
- The fronts are attached with screws located on the inside of the drawer.
- The widths and heights of the fronts vary depending on the drawer size (e.g., 40, 60, 80 cm (16, 24, 31.5 inches) wide).
- When replacing, it is essential to ensure that the new front has the exact same dimensions and drill holes.
- Different versions (e.g., with handle profiles or handleless fronts) result in different mounting methods.
If the old front is damaged, you can generally replace only the front without needing to change the carcass or other parts. This also applies when changing colors or styles. It is advisable to note the exact article numbers in advance and verify them using the Ikea planner or in-store.
Well, I think there’s a simple side to this as well: Ikea products are very modular and standardized, designed exactly for these kinds of situations! 😎
If you imagine the fronts almost like interchangeable outfits for your drawers, you’ve got the idea. You can take them off, put new ones on – done.
This is especially helpful with Metod cabinets when you want something fresh, or if your cat accidentally scratched them (which happens faster than retraining the cat 😄).
Important: Take your time when removing the fronts, and be careful with the screws on the back. Also, when buying new fronts, make sure they match your drawer types; otherwise, they won’t fit properly.
It’s basically a small DIY project that really pays off!
Great question! I recently did this at my home, and I can definitely say: it’s totally worth it!
Sometimes you just want a new look for your kitchen, but the cabinets are still in great condition. In my opinion, replacing the cabinet fronts is a brilliant solution.
For me, I simply loosened the screws from the inside and removed the old fronts. The new fronts had to have exactly the same dimensions, but once that was ensured, they went on quickly and hold very well.
I also chose new handles because the old ones were integrated, which gave a fresh new feel. So I can definitely recommend it—don’t be afraid to make the change!
A Brief Guide to Replacing Drawer Fronts on Ikea Metod:
1. Remove the front:
- Fully pull out the drawer
- Unscrew the screws fixing the front from the inside (usually 2-4 screws, depending on width/height)
- Carefully pull off the front
2. Check the new front:
- Compare measurements with the old front (height x width)
- Check the distance between screw holes (usually standardized for Metod)
3. Install the new front:
- Attach the front to the drawer with screws
- Ensure it is properly aligned
Common mistakes:
- Purchasing incorrect sizes
- Screws tightened too much or too little
- Not paying attention to the type of front (handleless or handle rail version)
Conclusion: Replacement is quite doable, and Ikea also sells fronts separately. You just need some patience for careful work.
Common mistakes:
