ᐅ Which tools are essential for assembling Ikea Metod drawers?
Created on: 24 Sep 2023 18:37
martar40
martar40
24 Sep 2023 18:37
Hello everyone, I am currently planning to assemble a kitchen using the Ikea Metod drawers and want to make sure I have all the necessary tools ready from the start to ensure a smooth assembly without major delays.
My question to you is: Which tools are absolutely essential for assembling Ikea Metod drawers to guarantee a secure and clean installation?
I am interested both in the tools needed directly for assembling the drawers and those helpful during preparation, such as for alignment or fine-tuning.
I would really appreciate it if you could share your experiences and maybe explain why you recommend these tools or if there are any that might seem useful but are not really necessary in your opinion. Thanks in advance!
Nabla64
24 Sep 2023 19:12
Good question, Martar40! For assembling the Ikea Metod drawers, I recommend the following tools that have proven to be indispensable in practice:
- Phillips screwdriver (PH2): For screwing most components.
- Cordless drill/driver: Saves time and effort, especially when dealing with many screws.
- Spirit level: To ensure the drawers don’t stick or run crooked later.
- Tape measure or folding rule: For precise measuring and alignment.
- Rubber mallet: Sometimes needed for gentle tapping without causing damage.
A tip: The screws included in the kits are usually good quality, but it’s worth making sure you have the right bits to avoid stripping screws. Precise alignment is also essential for the drawer slides, so don’t underestimate the spirit level!
Summary: Hand tools plus a cordless drill and a good measuring device make the job easier.
BAUEVA
24 Sep 2023 22:08
Nabla64 schrieb:
For assembling the Ikea Metod drawers, I recommend the following tools that have proven essential in practice:
It’s interesting that a cordless drill is considered standard here. At this point, I would suggest a more nuanced view: if you often rely on the supplied screws and their pre-drilled holes during assembly, a cordless drill can indeed be helpful. However, too much torque can easily damage the chipboard.
Furthermore, there is the question of whether special squares are needed to check for right angles. In my opinion, a spirit level alone is not sufficient, especially with larger cabinet combinations.
My recommendation: a torque wrench or at least a screwdriver with a torque-limiting feature, and a carpenter’s square. Being “quickly done” doesn’t help if the drawers stick or warp later on.
Overall, you shouldn’t rely on the tools alone but also critically review the assembly instructions and, if in doubt, measure one more time.
neoren
25 Sep 2023 08:44
In short: a Phillips screwdriver, a cordless drill, a tape measure, a spirit level, and possibly a small hammer or rubber mallet – that’s enough. Specialized tools are often unnecessary if you work carefully.
Laukau5
25 Sep 2023 15:26
BAUEVA schrieb:
If you don’t often rely on the included screws and their pre-drilled holes during assembly, a cordless drill can definitely be helpful. However, too much torque can quickly damage the chipboard.
I fully agree with that. Here are a few additional tips:
- Be sure to use a cordless drill with adjustable torque settings, so you don’t drive the screws too deeply. Wood chips in the holes can otherwise splinter.
- As a supplement to a protractor, a simple combination of a metal square (e.g. 30x20cm (12x8 inches)) and a spirit level is enough to ensure the drawer fronts fit perfectly.
- For installing the Metod drawers, a small flathead screwdriver is handy, since some adjusters need to be fine-tuned with it.
- Optionally, clamps are useful when you want to hold parts in place while screwing or aligning the cabinet.
A question for you, Martar40: Are the drawers delivered pre-assembled, or do you build them completely yourself? That influences which tools you will definitely need.
