ᐅ Which tools are essential for a quick and correct assembly of Ikea BESTA?
Created on: 23 Sep 2020 08:37
SenankinI am currently planning to assemble an Ikea BESTÅ furniture system and am looking for the most efficient list of tools to complete the assembly quickly and correctly. I am especially interested in which tools, based on your experience, are absolutely essential to avoid mistakes and prevent the process from taking longer than necessary. Are there any specific tools you would recommend, or tips on how to supplement the included hardware? Maybe also suggestions on the best way to organize the assembly of the numerous connecting fittings? I would greatly appreciate any advice based on practical experience.
Alberto5123 Sep 2020 09:11Hello Senankin, I know the feeling when you first sit down with a building kit and aren’t sure if you have everything you need. For me, a cordless screwdriver with the right bits was a total game changer. Before, I thought you were supposed to use the supplied hex key, but honestly, that didn’t speed things up much.
Having a non-slip mat and a tape measure also helps a lot to keep everything in place. At first, I struggled with the small screws and pinholes, which can quickly become frustrating. I often took breaks in between because I missed something, which obviously extended the time even more.
How about you? Do you have everything ready?
Senankin, let me organize this a bit so we can address all points systematically. For assembling the BESTÅ, I recommend the following basic tools:
- Cordless screwdriver with 4-5 Nm torque to avoid over-tightening the screws.
- Allen key (usually 4 mm), typically included, but mainly for retightening rather than full assembly.
- Phillips screwdriver (PH2) for some concealed screws.
- Angle square to align the units correctly.
- Rubber mallet to gently tap dowels and connectors into place.
Common mistakes often occur when screws are overtightened or parts are not properly aligned before fastening. A tip: always dry-fit all connecting parts first and check their fit before final assembly. This helps to avoid rework.
I also recommend using sorting trays to keep small parts organized and prevent loss. Do you have something like that planned?
refinar schrieb:
For assembling the BESTÅ system, I recommend the following basic tools: This is already very well prepared! I’ll add a casual tip: Put on your favorite audiobook and turn the assembly into a little feel-good moment.
On top of that: A bit holder with a depth stop for your cordless drill can often save you headaches, otherwise, you might screw in too far, and then things get tricky. 😉
My secret weapon was also a small LED work light, because the cabinets tend to be dark and cramped. I felt like I built better and faster this way—even if it’s not scientifically proven.
What’s your working environment like, Senankin? Are you assembling the piece solo or with a partner?
Alberto51 schrieb:
For me, a cordless drill with the right bits is an absolute game changer. That makes sense, I actually have a drill like that too, but I’m careful with the torque to avoid damaging the press-fit rivets.
refinar schrieb:
Errors often happen when screws are over-tightened or parts aren’t properly aligned before screwing. That’s an important point; for that reason, I prefer to focus on spacing and precise alignment before tightening everything.
Katan schrieb:
A bit attachment for the cordless drill with a depth stop can often save your head Do you have specific models or brands you would recommend? And how sensitive are the depth stop settings? I plan to assemble mainly on my own but want to be careful not to damage the parts.
Hello everyone!
From my own experience, I can confirm that assembling the IKEA BESTÅ is really enjoyable with the right tools. It’s especially motivating when you notice the screws fitting quickly and precisely.
I always carry a small torque wrench for hex screws, which prevents overtightening. I believe this really saves a lot of trouble with cracked panels or damaged knock-in fittings. My tip: always work in stages, for example, first assemble the base panel and then the upper sections. Take your time, and the process will be faster and much cleaner.
And very important: significant progress often isn’t about quick assembly, but the final result that stands there afterwards! Good luck to you all!
