ᐅ Which spare parts are the easiest to replace yourself on a BILLY?
Created on: 10 Dec 2016 08:42
Renra48
Hello everyone, I am currently looking into which replacement parts for Billy shelves are easiest to replace on your own without requiring extensive tools or specialized craftsmanship skills. I am particularly interested in commonly needed parts such as shelves, screws, or connectors, but also options for replacing damaged side panels or back panels. Who has experience with do-it-yourself replacements and can share tips on which parts are simple to change yourself and what to watch out for? Thanks in advance!
difepeo
10 Dec 2016 12:12
I would like to point out that the assumption that back panels are generally more difficult to replace does not necessarily apply in every case.
Penau schrieb:
Back panels are usually nailed or stapled, making replacement more complex
There are model variants where back panels are screwed in. In such cases, replacement is quite straightforward. However, it is worth mentioning the lack of design flexibility in Billy-style shelving units; by default, back panels are simply nailed.
Furthermore, it is advisable to carefully consider whether a full replacement is truly necessary or if localized repairs with wood glue or veneer would suffice.
Mufato
11 Dec 2016 07:52
I recently had a BILLY with a broken shelf board. Replacing it was quick and easy: just remove the shelf supports, insert the new board – done. I didn’t change the screws because they weren’t loose.
I haven’t replaced the back panels yet; that sounds more complicated.
Sepele
11 Dec 2016 09:18
As an additional note for anyone looking to gain confidence with DIY:
When replacing screws or shelf supports, it is advisable to use original replacement parts from IKEA directly, as these fit precisely and ensure material quality.
For example, when replacing a shelf support yourself, make sure it fits exactly into the groove – supports that are too loose cannot bear the load, and those that are too tight can damage the wood.
Regarding non-visible parts (such as dowels or back panels): I recommend caution here, as insufficient repairs can lead to long-term instability. In such cases, it may be more sensible to seek professional assistance.
In general, shelves, shelf supports, and screws are technically among the easiest replacement parts to change on BILLY.
Renra48
11 Dec 2016 10:05
Thank you for the explanations so far. I’m wondering if anyone has experience with replacing the side panels?
Are the glued or screwed joints really that difficult to break open or repair? Or are there any tricks one should know to replace the side panels without having to disassemble the entire shelving unit?
PRA64
11 Dec 2016 10:37
Good question, Renra48. Regarding the replacement of the side panels on BILLY:
The side panels are usually joined with dowels and glue and are often screwed in place. This design is not intended for frequent removal.
Important: You will often need a rubber mallet to carefully loosen the unit without damaging any parts. Unscrewing the screws is the first step here.
If the side panel is damaged, I recommend the following procedure:
1. Lay the unit flat on its back.
2. Unscrew all the fixing screws on the side panel.
3. Gently pry the side panel off bit by bit using a thin spatula or wooden wedge.
4. For strong glue bonds, applying some heat (e.g., a hairdryer) can help soften the adhesive.
Summary: Installing the side panel is considerably more complex than replacing shelves. It’s doable but requires patience.
neoren
11 Dec 2016 11:01
Replacing side walls yourself is complicated. Shelves, screws, and floor supports are the easiest.
