ᐅ How can I prevent the shelves from sagging on a Billy bookcase?
Created on: 30 May 2015 14:07
temeo1Hello everyone, I have a specific question about the shelves in IKEA Billy units: How can I prevent the shelves from sagging when I load them with quite heavy items? I understand that the standard shelves have a limited load capacity, but I am looking for practical and cost-effective ways to sustainably increase stability and load-bearing capacity – without having to replace the shelves entirely. What experiences have you had? Are there proven reinforcements, inserts, or other solutions that effectively prevent sagging without affecting the appearance or functionality of the shelf?
Hello temeo1, your concern is quite practical since sagging in Billy shelves often occurs and is limited by the particleboard used. I would like to explain some technical details to help you more precisely:
First, it is important to know that the official load capacity of a Billy shelf is about 13 kg (29 lbs) in the center. This is based on a defined distribution and a load spread over the shelf surface.
There are several strategies to prevent sagging:
1. Reinforcement with additional cross braces: Profile strips made of wood or metal are screwed to the underside of the shelves. These significantly increase bending stiffness by acting as stiffeners.
2. Replacing the shelves with thicker wooden boards: An 18 mm (0.7 inch) thick plywood or MDF board instead of the usual 16 mm (0.6 inch) particleboard reduces sagging but is considerably more expensive.
3. Installing center supports: A vertical support made of wood or metal in the middle of the shelf absorbs bending forces and thus prevents sagging.
4. Avoiding concentrated loads: If possible, distribute heavy items more evenly and avoid placing them only at the shelf’s midpoint.
I am curious: What loads are you planning to put on the shelves specifically? Are you dealing with many small or a few large heavy items? This can greatly influence the choice of solution.
Hello temeo1, I would like to add some information about why bending occurs in Billy shelves, especially under centered loads: The shelves are relatively thin and made of particleboard with a thin melamine coating – this makes them affordable but results in comparatively low bending stiffness.
I recommend a combination of several measures:
- Use shelves with a minimum thickness of 16mm (0.63 inches) or replace them with plywood boards.
- Install support strips made of wood or metal underneath the shelf, securing them with screws.
- Distribute heavy loads as evenly as possible, avoiding concentration on a single point.
If you like, I can also provide exact measurements and sources for such reinforcement materials.
