ᐅ How can I reinforce BILLY shelves without altering their appearance?
Created on: 29 Apr 2019 08:13
logaix
logaix
29 Apr 2019 08:13
I bought a Billy bookshelf from IKEA and want to reinforce the shelves without visibly changing the appearance of the unit. My main goal is to increase the load capacity of the shelves since I plan to store heavy books and some technical equipment on them. Could you please share tips on which methods or materials are suitable to strengthen the shelves internally, so that nothing is noticeable or altered from the outside?
I would also appreciate advice on whether the reinforcement should be applied directly along the edges or rather over the entire underside of the shelves, and whether it is better to use additional wooden strips or thin metal profiles. Thank you in advance for your recommendations!
taudi
29 Apr 2019 08:49
Hello logaix,
your question is well formulated and very specific. To discreetly reinforce the shelves of your BILLY bookcase, a few solutions are available:
1. Glue wooden strips under the shelf: Thin, sturdy strips (e.g., beech or pine) in the same color as the bookcase can be attached either over the entire surface or along the edges. This significantly increases the load capacity without affecting the appearance if the strips remain on the underside.
2. Thin metal profiles: Aluminum angle profiles are very sturdy and can also be mounted underneath. They are very slim and barely noticeable if installed flush. Short screws (preferably from inside or below) hold them securely.
3. Plywood reinforcement: A thin plywood panel, cut exactly to shelf size and glued or screwed under the shelf, distributes the load more evenly.
Important: Make sure not to drill screws or nails through the top surface of the shelf. Wood glue can also help secure the reinforcements.
If you need more details, feel free to ask!
V
vin_leo
29 Apr 2019 09:06
I understand your wish for the shelf not to look bulky like a tank, but rather to have a nice, subtle appearance. :-)
A great option is to reinforce the shelves from underneath with solid wood strips. You can attach these so that they are not visible at all. If you match the color with the shelf (or even paint the strips), the whole setup becomes almost invisible.
Even better: look for thin metal brackets, preferably with a powder-coated finish in white or oak, depending on what matches your shelf best. Simply screw them on from below—this provides a lot of support and is very practical.
This saves you the effort of hiding the supports and adds a lot of stability. 🙂
logaix
29 Apr 2019 09:24
taudi schrieb:
1. Glue wooden strips under the shelf board...
Thank you for the detailed information! Could you tell me how thick these wooden strips should be? I don't have any experience with material thickness in this situation. Do you think 10 mm (0.4 inches) is too thick, or maybe 5 mm (0.2 inches) is better? Or does it depend more on the type of wood?
vin_leo schrieb:
If you match the color with the shelf (or even paint the strips), it will become almost invisible.
I also think that’s important – I don’t want a “patch” on the bottom that stands out. How durable is the glued connection if I only use adhesive for the strips? Or would it be better to screw them in?
taudi
29 Apr 2019 09:35
Regarding your questions:
A thickness of 8 to 10 mm (about 0.3 to 0.4 inches) for the strips is usually sufficient. Anything thinner than 5 mm (0.2 inches) might not provide enough stability, especially if heavy loads are expected. The type of wood is also important: hardwoods like beech or ash are more stable than pine or spruce, but they are also more expensive.
As for fastening: glue alone can hold a lot, especially if you use high-quality wood glue and clamp the surfaces well, for example with clamps.
However, to be completely safe, small screws are advisable—ideally inserted from underneath so they are not visible from the outside. A combination of gluing and screwing ensures long-term stability.
Important: avoid placing screws too close to the edge to prevent the wood from splitting.
Timofa
29 Apr 2019 10:13
Hey logaix 🙂
I recently gave my Billy shelves the exact same upgrade! I used thin aluminum brackets that I screwed in from underneath. The brackets are only 10 mm (0.4 inches) wide and have no sharp edges, so they are hardly noticeable.
The best part: you can even position the bracket so that it sits just behind the shelf board, making it almost invisible. My shelf now holds a lot more weight, and the appearance remains completely intact.
A small tip: if you use screws, choose ones with a flat head and countersink them slightly into the wood so nothing sticks out underneath.
