Hello everyone, I have a problem with my Billy bookshelf: over time, the shelves tend to bend, especially under the weight of heavy books and other items. I’m looking for a practical and reliable way to reinforce the shelves without changing the original appearance or having to rebuild the entire unit. How have you solved this issue with your Billy bookshelves? Which materials work well to prevent the shelves from sagging? Are there any special tips or considerations to keep in mind when reinforcing the shelves to ensure it holds up in the long term? I’m looking forward to your advice and experiences!
Z
zarHenning11 Mar 2021 10:27I recommend metal angle brackets as a support structure, which are screwed under the shelves at both the front and back. This way, the shelf surface remains visually unchanged, and the load is well distributed.
Hello Lareku,
Your concern is understandable, as the particleboard shelves used in Billy units can bend over time when loaded. In general, there are several ways to improve this:
1. Reinforcement with metal profiles: As mentioned, flat angle brackets fixed with small screws to the underside of the shelf work well. This increases load capacity without being visible.
2. Replacing the shelves: If possible, you can use thin plywood or multiplex panels, which are more stable and hardly flex. You can either replace the shelves entirely or glue the reinforcing panels to the underside.
3. Installing supporting intermediate braces: A wooden strip screwed on the left and right or across the underside of the shelf significantly stabilizes it.
It is important that the reinforcement sits flush and is secured with screws of sufficient length. This distributes the load and protects the shelf long-term.
I hope this helps you already!
Lareku, to reinforce Billy shelves, there are proven methods:
- Use U-shaped profiles made of aluminum or steel on the underside to increase stiffness.
- Reinforce with plywood panels at least 12 mm (1/2 inch) thick.
- Install a central support within the shelf frame if the shelf is wide.
Screws should be countersunk from below to avoid visible marks. Additionally, using wood glue when bonding panels together is recommended. Combining several of these measures significantly improves the load capacity.
Hello Lareku,
if you want to effectively address the problem of the Billy shelf boards bending, you should take a closer look at the material properties of the original board and the load distribution.
The standard shelves are made of particleboard with a thickness of approximately 16mm (0.6 inches), which tends to bend quickly under heavy loads. The modified solution involves a combination of:
- Gluing a 6–8mm (0.25–0.3 inches) plywood or multiplex board to the underside, preferably with waterproof PU glue to create a permanent bond.
- Screwing this reinforcement every 20–30cm (8–12 inches) with countersunk screws to prevent shifting.
- Optionally, attaching a narrow steel or aluminum strip lengthwise in the center to limit deflection.
Be sure to pre-drill holes for the screws to avoid splitting. Avoid excessive loads or wide shelves without center supports, as the maximum bending depends greatly on the span length.
If you wish, I can provide a detailed calculation of the required stiffening dimensions if you provide the shelf measurements and expected loads. Precision is key here for me!
