ᐅ What helps prevent deformation of BILLY shelves under heavy loads?
Created on: 20 Jun 2015 08:37
Buge36
I have a somewhat specific issue with my BILLY shelves from IKEA: under heavy load, the shelves noticeably bend, especially in the middle, which of course affects both stability and appearance over time.
My question is: What exactly helps prevent bending of BILLY shelves under heavy load? I mean concrete measures like reinforcements, certain materials, special supports, or other tricks. I have considered adding cross braces or additional center supports but am unsure what is actually recommended and practical to implement.
I look forward to expert tips and experiences—feel free to share specific products or your own solutions.
Thanks in advance!
Thanks in advance!
Regarding your question about multiplex plywood as an alternative: Multiplex plywood is significantly more stable and less prone to bending than standard particleboard due to its cross-laminated veneer layers. However, it is also considerably heavier and usually more expensive.
If you choose multiplex plywood, make sure it has sufficient thickness (at least 18 mm (0.7 inches)) to achieve a noticeable improvement. Additionally, I recommend not using the full width of the shelves, as long spans can always be problematic.
Regarding metal profiles: Yes, U-profiles or angle profiles made of aluminum or steel can serve as a smart reinforcement solution. They should be installed in a way that enhances load capacity without negatively affecting the shelf’s appearance or functionality. For example, mounting them along the entire length of the shelf where the greatest load is expected.
A small tip: When installing metal reinforcements, be sure the materials are thermally compatible to avoid potential stresses.
What are the dimensions and intended use of your shelf (height, width, usage) so the load can be better assessed?
chentan schrieb:
Multiplex is significantly more stable and less prone to bending than conventional particle board.Exactly! And if you add an extra layer of clear varnish on top, it becomes almost indestructible! 🙂
But hey, a classic Billy shelf with a steel upgrade also sounds like a fun DIY project.
NAU34 schrieb:
Billy shelf with steel upgrade sounds like a DIY adventure.The best solutions are usually simple and effective. I always say: just add metal brackets underneath, done. More effort often doesn’t bring proportional benefits.
For a practical tip: With heavy loads, it is advisable not only to reinforce the shelves but also to add extra stabilization to the entire shelving unit. For example, by attaching a plywood back panel (at least 6 mm (1/4 inch)) that stabilizes the frame against twisting.
Please pay attention to the type of fastening used, as the back panel also distributes the vertical load and significantly influences the overall stability concept of the shelving unit.
Hello Buge36 and everyone following this! It’s great to see some really good ideas already coming together here!
I reinforced the shelves of my BILLY bookcases with strips of spruce wood—simply screwed underneath the shelf boards. Since then, everything has held really firmly, even when I place heavy stacks of books on them.
Important: Be patient when drilling! ;-) And always work with momentum, then it will work out!
Keep it up, we’ll solve this problem! 🙂
Wow, great tips so far! I completely agree with noge58 – reinforcing with wooden battens is really simple and effective!
What I can also recommend is to regularly unload the shelves and avoid overloading them, even though the modifications can support a lot of weight. Additionally, small adjustable feet under the shelving unit can prevent the frame from warping due to the load.
If you’re interested, just try out the wooden battens first – the costs are manageable, and the effect is quickly noticeable.
