ᐅ Billy Regal curved shelves: How to reinforce them?
Created on: 11 Mar 2021 10:03
Lareku
Hello everyone, I have a problem with my Billy bookshelf: over time, the shelves tend to bend, especially under the weight of heavy books and other items. I’m looking for a practical and reliable way to reinforce the shelves without changing the original appearance or having to rebuild the entire unit. How have you solved this issue with your Billy bookshelves? Which materials work well to prevent the shelves from sagging? Are there any special tips or considerations to keep in mind when reinforcing the shelves to ensure it holds up in the long term? I’m looking forward to your advice and experiences!
kloreo
12 Mar 2021 10:12
I would try using a steel rod, which you screw in the middle underneath the board. This gives the shelf impressive stability without being very visible.
TEBILO
13 Mar 2021 08:50
Lareku schrieb:
Does the bonded panel remain inconspicuous, or is it noticeable somehow?
The panel is attached to the underside of the shelf, so it is visible when looking from below, but from the front or above, the shelf’s appearance remains unchanged.
Lareku schrieb:
How does the moisture resistance hold up if these reinforcements are glued, for example, with wood glue?
Using waterproof PU adhesive is essential for resisting moisture. Standard wood glues are not suitable for increased moisture exposure and may lose adhesion.
For household environments where surfaces are only occasionally wiped, PU adhesive is completely sufficient.
If the shelf is located in a damp environment, applying an additional surface protection to the reinforcement, such as clear varnish, would be advisable.
If you provide more details about your intended use, I can recommend suitable products.
