ᐅ What issues are more common with large Billy bookcases?
Created on: 6 Aug 2023 09:12
Kolijo
Hello everyone, I would like to ask a fairly specific question here: What problems tend to occur more often with large Billy bookcases from IKEA when they are used for an extended period or loaded with heavier weights? I am particularly interested in potential stability issues, warping, possible material fatigue, or damage at the joints. Maybe you also have experience with proper assembly or usage to ensure the bookcase remains stable. I am mainly concerned with the larger versions (more than 80 cm (31 inches) wide and 200 cm (79 inches) tall), rather than the smaller models. Thanks in advance for your insights and advice!
kasan
6 Aug 2023 11:29
I believe the quality of materials should also be critically examined here. The particle boards used in Billy shelves are known to have their limits.
DULIS schrieb:
In large Billy shelves, the shelves often warp when heavy loads are placed on them.
That is certainly true, but we should also not forget that the edges and glued joints can show signs of fatigue relatively quickly when exposed to moisture or temperature fluctuations. It would be interesting to know how often long-term loads under varying humidity levels have been recorded here.
Laukau5
6 Aug 2023 13:47
I would like to address some potential issues with large Billy-style shelving units in more detail, as I have gathered some experience:
1. Material deformation: The shelves are usually made of particleboard, sometimes with a laminate coating. Under prolonged load, they tend to warp or even delaminate, especially if the load is unevenly distributed.
2. Back panel: The back panel is often a thin hardboard sheet that contributes significantly to the stability of large cabinets. If it is not properly fastened, overall stability is greatly reduced – the unit can feel unstable and may be prone to tipping.
3. Joints: Screws, dowels, and brackets can loosen due to movement or improper assembly. This is particularly critical for large furniture pieces that are moved frequently.
4. Wall anchoring: Although wall mounting is often recommended, it is sometimes neglected – especially with larger models, this greatly increases the risk of tipping accidents.
Are there any specific stresses or environmental factors in your situation (e.g., humidity, frequent relocation)? This could help narrow down the causes further.
Kolijo
6 Aug 2023 14:02
Laukau5 schrieb:
Do you have any specific loads or environmental factors, such as moisture or frequent moving?
Thank you for the detailed reply! To answer that: The shelf is located in a dry, heated living room and is rarely moved or shifted. It is mainly loaded with books, some of which are very heavy reference volumes. The wall mounting is currently temporary, so it is not yet fully secured. The issue is that I have noticed sagging and slight wobbling, even though the back panel is installed.
Paxton38
6 Aug 2023 14:47
Kolijo schrieb:
The shelf is placed in a dry, heated living room and is rarely moved or repositioned. It is loaded with books, including heavy reference materials. The wall mounting has been temporary so far.
Under these conditions, sagging of the shelf board under heavy load is to be expected. The particleboard shelves have a maximum load capacity, which is more quickly exceeded with longer shelf boards due to leverage. Installing additional center supports or metal brackets can help. It is also important to properly secure the wall mounting to completely prevent wobbling.
theo63
7 Aug 2023 09:11
I would like to offer a somewhat more critical perspective here: The recommendation to simply screw metal brackets under the shelves is practical, but it overlooks the underlying structural issues. If the chipboard shelves already sag under heavy load, this indicates a fundamental limitation of the material and the construction method.
nedagla schrieb:
simple and effective!
– yes, but I wonder whether this is a long-term solution or more of a temporary fix.
It would be better to consider whether a different shelf model or a custom-built piece of furniture might be more appropriate for such requirements.
kasan
7 Aug 2023 10:15
theo63 schrieb:
If the particleboard floors already sag under heavy loads, this indicates a general limitation of the material
I agree with that. Additionally, it would be interesting to know how the load is actually distributed. Many people simply place their books centrally on the floor, which creates higher point loads than an even distribution.
Perhaps there should also be a discussion on whether the IKEA assembly instructions adequately address these issues and whether they provide specific load recommendations or reinforcement options.
