Hello everyone, I would like to ask a fairly specific question here: What problems tend to occur more often with large Billy bookcases from IKEA when they are used for an extended period or loaded with heavier weights? I am particularly interested in potential stability issues, warping, possible material fatigue, or damage at the joints. Maybe you also have experience with proper assembly or usage to ensure the bookcase remains stable. I am mainly concerned with the larger versions (more than 80 cm (31 inches) wide and 200 cm (79 inches) tall), rather than the smaller models. Thanks in advance for your insights and advice!
Problems with large Billy shelves usually arise from exceeding load limits. The shelves are made of particleboard, which bends over time if subjected to excessive weight. Wall fixing is also important, as the height and width increase the risk of tipping accidents. It is recommended to anchor the shelf to the wall using appropriate wall plugs and screws to ensure stability. Joints between the side panels and shelves can loosen over time with frequent rearranging or moving.
It’s great that you’re asking such a specific question! 🙂 I also had issues with sagging shelves on my large Billy, especially under heavy books. But after I screwed two small metal brackets under the shelves, the problem was gone. Simple and effective! Also, the back panel bowed slightly in one spot, so I secured it with small nails – it holds perfectly!
Large Billy bookcases are somewhat the little dramas of living room furniture 😉 Often, the problem is that over time they warp slightly, which not only looks unattractive but also makes organizing more difficult. Especially with large shelves, you notice that the back panel plays a major role – if it’s not properly secured, the whole unit becomes quite wobbly. My advice: always assemble carefully and check the screws regularly. That way, there won’t be any surprises!
