ᐅ How can you prevent the back panel of BILLY bookcases from breaking?
Created on: 11 Jul 2021 09:13
luce35Hello everyone, I have a problem with the back panels of my Billy bookcases tearing or even breaking during load testing in certain areas. The bookcase is usually placed against a wall, is not overly loaded, and I have already been careful during assembly. Still, it happens regularly, especially when I want to store somewhat heavier items. I’m wondering how to practically and permanently prevent the back panel of Billy bookcases from breaking. Are there any special tips that IKEA might not explicitly mention? Maybe it’s a matter of screw technique, the material, or additional reinforcements? I would appreciate detailed advice, especially solutions that work long-term and can be implemented without much effort.
The most important thing is to install the back panel correctly. The thin board mainly serves as stabilization and is not designed to bear independent loads. Make sure the back panel fits flush and without warping between the cabinet sides, and that all nails or screws are firmly secured.
Additionally, small brackets or metal strips can be used inside to provide extra stability. Nails that are driven in too tightly or too loosely can weaken the material, which often leads to a risk of breakage.
Step-by-step guide to protecting the back panel:
1. Before installation, check that the back panel is not warped.
2. Use a rubber mallet to gently tap in the nails. Hard hits can damage the thin panel.
3. Consider cutting a sturdier wooden panel (e.g., a thin plywood board) instead of the supplied thin back panel.
4. Additionally, attach brackets at the corners to increase stability.
A common mistake is quickly and forcefully hammering the nails, which often causes cracks.
REPITAR schrieb:
A common mistake is hammering nails quickly and roughly, which often causes cracks. That explains a lot. I really was hammering with a regular hammer and not being very careful. Would it be better to use screws or small dowels instead of nails? Would they significantly improve stability or just make things more complicated?
Screws are generally more stable but could split the back panel since the material is very thin. An alternative is small flat-head screws with pre-drilled holes, provided you are confident in handling them.
For the average user, carefully driving in the supplied nails remains the recommended solution. Careful pre-drilling can also help but is not necessary.
