ᐅ What are the most common repairs for BILLY shelving units?
Created on: 24 Mar 2022 09:23
sanneo
sanneo
24 Mar 2022 09:23
Some time ago, I bought a few Billy bookcases from IKEA and have been using them in different rooms. I’ve noticed that some models have already developed minor issues—ranging from loose shelves to broken back panels.
I’m curious to know which repairs are most common with BILLY bookcases based on your experiences and observations. Do these problems tend to occur during assembly, daily use, or mainly due to material fatigue? Are there typical weak points that should be watched from the beginning?
I look forward to your feedback and tips to help me keep my bookcase in good condition for as long as possible.
lorena
24 Mar 2022 10:37
Hello sanneo,
regarding your question: "What repairs are most common with BILLY shelves?" I can share some insights from a technical perspective. Generally, the most frequent issues with BILLY shelves are the following:
1. Loose or damaged dowel holes – especially if the shelf is often disassembled and reassembled. The wooden dowels don’t last forever, and repeated removal and reinsertion can damage the wood around the hole.
2. Shelf cracks or warping – particularly under loads exceeding the recommended weight. Although the shelves are melamine-coated, they aren’t very thick and tend to sag.
3. Back panel problems – the thin hardboard back panel can easily crack or come loose if it is not properly secured during transport or when moving the shelf.
A tip: If you plan to modify the shelf frequently, consider using connector screws (cam locks) or metal fasteners instead of wooden dowels, as these hold better over time. Also, it’s advisable to attach the back panel with screws or specialized holders rather than nails, if possible.
I’m curious about the age of your shelf and how it is used. Is it mostly holding books or lighter items? That information could help narrow down the causes more precisely.
SUPE2
24 Mar 2022 11:04
Most of the time, loose screws and shifted shelves are the issues with BILLY units. Often, simply tightening or realigning them is enough.
RENMA
24 Mar 2022 12:29
Indeed, the main issue with BILLY shelves is primarily related to the connection points. IKEA’s technical datasheets explicitly state a maximum load of 30 kg (66 lbs) per shelf. Exceeding this often leads to cracks at the shelf mounting points.
Additionally, the back panel, made of thin hardboard, is not designed as a load-bearing element, which can result in a loss of stability if installed improperly.
In my opinion, strictly adhering to the specified load limits is the best way to prevent the need for repairs.
sanneo
24 Mar 2022 12:50
lorena schrieb:
I’m curious about how old your shelf is and how it’s used. Does it mainly hold books or lighter items?
The shelf is about 2 years old, located in my home office, and mostly holds books and binders. It is used quite heavily and rearranged from time to time. I have especially noticed that one of the shelves’ supports is starting to wobble, and there are small cracks visible on the back panel.
Rashadmeo
24 Mar 2022 13:13
Wow, that sounds like typical issues! 🙂
sanneo schrieb:
that one of the shelves is starting to have loose brackets
If the brackets are loose, you could try attaching small angle brackets on the inside to improve stability. This usually holds very securely and is super easy!
And the cracked back panel? I strongly recommend not putting any more weight on it and possibly fixing it with some wood glue or a thin piece of wood. That way, the shelf remains stable.
Next time, try not to put too much weight on individual shelves—it will then last for ages! Good luck! 🙂
