ᐅ How can I reinforce BILLY shelves without altering their appearance?
Created on: 29 Apr 2019 08:13
logaix
I bought a Billy bookshelf from IKEA and want to reinforce the shelves without visibly changing the appearance of the unit. My main goal is to increase the load capacity of the shelves since I plan to store heavy books and some technical equipment on them. Could you please share tips on which methods or materials are suitable to strengthen the shelves internally, so that nothing is noticeable or altered from the outside?
I would also appreciate advice on whether the reinforcement should be applied directly along the edges or rather over the entire underside of the shelves, and whether it is better to use additional wooden strips or thin metal profiles. Thank you in advance for your recommendations!
klo40
29 Apr 2019 10:45
I would like to add that the reinforcing strips can also be installed across the width of the shelf. It is important to position the strip with the edge running along the direction of the load, meaning the widest side of the strip distributes the load. This significantly increases the stiffness of the shelf board.
If the shelf will be heavily loaded, you can also add a central support strip (a strip running from front to back in the middle of the shelf). This method is very effective without affecting the appearance, as the reinforcement remains underneath the shelf board.
For a more professional approach, you can use plywood where the wooden strip also serves as edge protection.
And: please ensure precise measurements, otherwise you may cause stress in the shelf board later on. This damages both the appearance and stability.
barda6
29 Apr 2019 11:04
Strips 10 mm (0.4 inches), wood glue plus screw from underneath. No risk, maximum stability, invisible from above.
Ezekiel
29 Apr 2019 11:32
For clarification:
Billy shelves are typically made of MDF with a thin foil coating. This construction tends to bend under heavy load.
Reinforcing the underside of the shelf with a glued wooden batten (at least 10 x 20 mm [0.4 x 0.8 inches] cross-section) is technically advisable, as it increases the bending moment and thus improves resistance to sagging.
Metal profiles must also be sufficiently sized to have a significant effect; attention should be paid to decoupling the foil coating to avoid visible deformations.
Attaching battens without screws is possible, but from a long-term perspective, using screws is recommended to ensure effective load transfer and prevent settling.
In summary: the best solution is a combination of glued and screwed hardwood battens with a minimum thickness of 10 mm (0.4 inches), attached from the underside to avoid affecting the appearance.
An additional central reinforcement further increases load capacity and prevents sagging on wider shelves.
Deoren
29 Apr 2019 11:47
Glue and screw wooden battens, 10 mm (0.4 inches) thick, from below. This preserves the appearance and increases load-bearing capacity.
Klakar
29 Apr 2019 12:11
Reinforce the underside of the shelves with wooden strips at least 10 mm (0.4 inches) thick, glued and screwed from underneath; this is more reliable than using glue alone.
V
vin_leo
29 Apr 2019 13:22
Just a quick and casual tip: Want to strengthen the shelves of your BILLY bookcase in a neat and invisible way? Get thin strips about 10mm (0.4 inches) thick, sand them smooth, and paint them to match. Attach them from underneath using wood glue and a few small screws – no one will see it, but it feels sturdy.
It sounds like a DIY project, but it’s really quite simple and even enjoyable. Then you can safely put your heavy books on the shelves 😉 Good luck!
