ᐅ How can I prevent sagging and bending in BILLY bookshelf shelves?
Created on: 8 Sep 2022 14:07
Minmaximo9M
Minmaximo98 Sep 2022 14:07Hello everyone, I have a somewhat specific question: How can I reliably prevent sagging and bending of the shelves in IKEA Billy bookcases? I mainly use the shelves for books and some heavier items, but I have noticed several times that the shelves bend under heavier loads, which not only looks unattractive but also reduces stability. I am interested in both recommended load limits and ways to improve the shelves’ strength, for example through additional supports or reinforcements. Are there any practical tips or experiences on how to achieve this with minimal effort and without major modifications? Thanks in advance for your help!
SauDietmar8 Sep 2022 14:23Hello Minmaximo9,
I’m very familiar with this issue and will explain step by step how you can minimize sagging and bending in BILLY shelving boards.
1. Observe the load limit: The official load capacity is usually around 15-30 kg per shelf, depending on the width. If you store heavier books, you should not exceed the maximum allowed weight.
2. Add additional center supports: The most effective method is to install a center support under the shelf. This significantly reduces bending and stabilizes the entire surface. You can use a wooden dowel or a metal bar fixed exactly in the middle.
3. Optimize shelf thickness: If you can replace the shelves, I recommend 16 mm (0.63 inch) thick wood panels instead of the thinner standard shelves. More material under load means less deformation.
4. Reinforce the side panels: In the BILLY series, the side panels are often thin, which contributes to sagging. Consider reinforcing the sides with additional wooden battens or metal brackets.
5. Maintain adequate spacing between shelves: The closer the shelves are placed (e.g., every 25-30 cm (10-12 inches)), the less weight each shelf carries, which reduces bending.
Summary: Stick to the maximum load, install center supports under heavy shelves, and consider replacing the shelves with stronger ones. This should effectively prevent sagging.
If you like, I can also provide some sources for suitable reinforcements.
Hello Minmaximo9,
From my experience, the 80cm (31.5 inches) wide shelves of BILLY units tend to sag, especially under heavy loads. If you want to be on the safe side, it’s better to spread the books across multiple shelves and avoid placing too much weight concentrated in the middle, as that is where sagging is most noticeable.
Additionally, the shelves can gradually give way over the years due to moisture or temperature changes. Therefore, it’s important to regularly check them and adjust or replace as needed.
If you decide to add extra center supports, you can use wooden strips or metal brackets from a hardware store. They just need to be securely fastened to effectively provide support.
I hope these tips are helpful to you 🙂
SauDietmar schrieb:
Center supports and stronger shelves really help.
Due to the thin particle boards used for the BILLY shelves, typical load limits are around 15–20 kg (33–44 lbs). To prevent sagging, reinforcements are essential, especially with higher loads.
A central support beam made of wood or metal, mounted underneath the shelf in the middle, noticeably reduces sagging.
Alternatively, replacing the shelf with a 16 mm (5/8 inch) thick plywood panel provides significantly greater stability.
Additionally, the shelf sides should be stable and properly aligned, as unstable side panels can contribute to shelf sagging.
Regular inspections and adjustments are therefore recommended as needed to avoid warping or tension.
Minmaximo98 Sep 2022 16:11Thank you very much for all the answers; they are very helpful!
I would like to follow up: If I install a center support bar, what is the best way to mount it? Should I screw it directly into the floor or attach it from underneath? Is there a specific size or type of wood that is particularly suitable?
Also, I am wondering if it might be possible to add additional support legs under the shelves to transfer the maximum weight upwards. Does anyone have experience with this?
Last but not least: How critical are the shelving sides? In my case, they are somewhat flexible but not loose.
