Hello everyone, I am planning to use my Billy shelf with shelves from the classic Ikea frame for significantly heavier loads than usual. The included shelves are typically designed for relatively light to medium loads. My question is: how can these shelves be reliably reinforced so they can carry higher weights without bending or even breaking? Are there practical methods or materials to noticeably improve stability without a complicated rebuild? I am open to tips for mechanical reinforcement as well as tricks involving additional brackets or redistributing the loads. Thanks in advance!
JEREMIAH3818 Apr 2022 11:35I can definitely understand how frustrating it is when shelves start to sag or even bow despite careful use. I experienced the same issue about a year ago with a Billy shelf that I really valued. In the end, I added plywood panels as reinforcement and additionally screwed wooden battens underneath. That worked well for me, but I also thought it was important not to just increase the loads arbitrarily, but to organize the shelf intentionally. Sometimes it also helps to place the heaviest items at the very bottom. Maybe you can take that into account?
I like to go a bit more into detail: The reason for the sagging of the Billy shelves is the combination of the relatively low thickness of the particleboard (usually 16 mm (0.6 inches)) and the span of about 80 cm (31.5 inches). Under loads over 30 kg (66 lbs), tensile and compressive stresses occur that literally bend the board.
A specific reinforcement is worthwhile if you separate the shelf technically:
1. Remove the shelf board and cut a wooden or plywood strip to the span length, about 30-40 mm (1.2-1.6 inches) wide and at least 40 mm (1.6 inches) high.
2. Screw this strip centrally and from underneath onto the bottom of the board. A firm contact is important to increase the previously linear elasticity.
3. Alternatively, aluminum U-profiles are very effective; they act as beams similar to a T-beam.
Note: When mounting such reinforcements, they can easily interfere with the shelf slot. So check the fit beforehand. It is also a good idea to secure the side panels with additional supports or extensions for very heavy loads to avoid overloading the entire shelving unit.
If you like, I can also provide the exact dimensions and sources.
Matthewt4818 Apr 2022 12:21Hello, to revisit the topic: You can increase the load capacity of the shelf boards by replacing them with larger or thicker wooden boards. It takes a bit of effort, but it works. I also recommend building a shelf with an additional central support for heavy loads. Sometimes you see this in furniture sold in stores, where extra supports in the middle significantly improve load distribution. For the Billy shelf, which is relatively slim, this is more challenging, but perhaps a thin metal rod or a wooden strip could be added. Just a note: It’s also worth carefully checking the intended use of the shelf to make sure the side panels don’t end up breaking.
Thank you, that’s very helpful. @minan, your explanation sounds just right, especially the idea of using a strip as reinforcement. I will try to screw a strip underneath the plank floor. If these are the original measurements from Billy, I would need to reinforce an 80cm (31.5 inches) particleboard length. If you can provide the dimensions and sources, I would be grateful.
@Matthewt48, the idea of a central support sounds good, but I find it somewhat difficult to implement with Billy since the unit doesn’t have pre-drilled holes for additional supports inside. However, maybe I can find a solution with custom-made support strips?
Here are some dimensions and tips for your project:
- The standard Billy bookshelf shelf measures about 80 cm (31.5 inches) wide and 28 cm (11 inches) deep.
- For a reinforcing batten, use a wooden strip 30 to 40 mm (1.2 to 1.6 inches) wide and at least 40 mm (1.6 inches) high, preferably made of pine or plywood.
- Screws: Use screws with the smallest possible head to avoid damaging the board. 3.5 x 30 mm (1/8 x 1.2 inches) screws should be sufficient.
Procedure:
1. Cut the batten precisely
2. Pre-drill holes to prevent the wood from splitting
3. Position the batten exactly in the center (40 cm (15.7 inches) from the board edge) and fasten it with screws at least 5 mm (0.2 inches) deep
As @minan already mentioned, pay attention to the seating in the shelf frame. Once the board is installed, the load distributes better, and it bends much less.
Procedure:
