ᐅ Which BILLY shelves are better suited for long shelf boards?
Created on: 10 Sep 2020 09:12
kefrancis
I am planning to buy Billy shelves and want to use the longest possible shelves that still remain stable. My question is: Which BILLY shelf models are better suited for long shelves in terms of stability and load-bearing capacity?
I have seen that there are different constructions and widths, for example the standard size 80 cm (31.5 inches) and wider variants. Does anyone have experience with the long shelves in the different series and can offer tips on whether additional reinforcements or special materials are needed?
Thanks in advance for the help!
draleo
10 Sep 2020 11:56
Regarding metal supports: There are affordable retrofit solutions available on the market that can be installed under the shelves, even on standard Billy models. These increase connection rigidity and minimize sagging of long shelves.
Alternatively, there are special BILLY shelves with central braces that offer greater depth and stability.
As for wall mounting: BILLY shelves should always be secured to the wall using the included anchors and screws. The drilling depth depends on the wall type (e.g., concrete, drywall). Proper drilling ensures greater stability and safety.
Far34
10 Sep 2020 12:19
For a length of 100-105 cm (39-41 inches), you can use standard floorboards, but only if you add a support in the middle. Otherwise, it will sag noticeably.
blapau
11 Sep 2020 08:07
I have had very good experiences with the wider BILLY versions that come with a center support bar. These are a bit more expensive, but significantly more stable for long shelves.
The center support bar distributes the load well, which prevents sagging and makes the shelf overall sturdier.
However, wall mounting is essential. Especially for tall shelves with long boards, not securing them to the wall can lead to accidents when loading.
gasidney
11 Sep 2020 08:45
If you don’t want to build it yourself, use the wide BILLY shelves with a central support. Installation is easy, stability is excellent.
kefrancis
11 Sep 2020 09:11
TYRELL schrieb:
What exact length are you planning? It makes a difference whether the boards are 80, 100, or 120 cm (31, 39, or 47 inches) long.
To clarify: I want to use shelves about 105 cm (41 inches) long to make the most of the available space. It is important to me that the shelves do not sag under normal to heavy loads.
Far34 schrieb:
For 100-105 cm (39-41 inches) lengths, you can use standard shelves, but only if you add a support in the middle.
Regarding that: Are there simple, unobtrusive middle supports that fit BILLY, or would I need to make something myself?
Any tips are welcome.
TYRELL
11 Sep 2020 09:56
kefrancis schrieb:
Are there simple, discreet center supports that fit BILLY, or do I need to make something myself?
Yes, there are affordable metal brackets from third-party suppliers designed specifically for BILLY shelves that can be installed unobtrusively. Alternatively, you can screw short wooden strips under the shelf board, which significantly reinforces the load-bearing capacity – but that requires some DIY skills.
For a length of 105 cm (41 inches), I definitely recommend the 22 mm (7/8 inch) thick shelves, as standard shelves tend to sag even under light loads.
Another option is combining a center support with wall fixing; this provides the best protection against sagging and tipping.
