ᐅ Why does adjusting the shelves in a Billy bookcase often cause problems?
Created on: 18 May 2021 08:13
Guylau
Guylau
18 May 2021 08:13
Lately, I have noticed that adjusting the shelves in IKEA Billy bookcases often causes problems. This is not just about simply moving the metal pins, but also concerns the stability and fit of the shelves after adjustment.
More specifically: Why does adjusting the shelves in Billy units frequently lead to issues such as unstable construction, shelves falling out or becoming misaligned, and sometimes even damage to the unit itself?
I am interested in whether the design of the drilled holes, the material quality, the assembly system, or other factors are responsible. Has anyone experienced this as well? Based on your experience, how can these issues be explained? Are there any proven tips to minimize these problems?
Thank you in advance for your opinions and experiences!
semuneo
18 May 2021 08:45
Hello Guylau,
I am very familiar with this issue and think your question is very important because many people simply look for where the pins fit without considering stability.
From my experience, a big part of the problem is that the drill holes in the side panels are not always perfectly precise and even new shelves show slight tolerances. When you adjust the shelves multiple times or try to position them exactly level, this can lead to pins fitting too loosely and cause instability.
Additionally, I have the impression that especially with older shelves the wood around the holes swells or chips slightly, which worsens the problem.
It can be frustrating because you want to stay flexible, but the construction quickly feels fragile. I would be interested in tips on how to improve this without having to replace the entire shelf.
Joe52
18 May 2021 09:12
I completely agree, especially when placing heavy items on the shelves, you can immediately notice the weak point.
In my opinion, the difficulty in adjusting the shelves is also due to the metal pins often not providing a secure fit. Although they sit in the holes, they can shift or loosen slightly under load. This creates unnecessary stress on the side panels.
For such a popular product like Billy, I would have expected a more stable solution. Usually, you only start thinking about this when something tips over or a shelf shifts slightly, which can be frustrating during setup.
jotisi
18 May 2021 09:35
semuneo schrieb:
the drilling in the side panels is not always completely precise
Of course, that’s exactly the point! But honestly, what can you expect from a mass-produced product at that price?
Sometimes IKEA really frustrates me because they focus on quantity and low prices, but the quality of workmanship then suffers.
I consider the adjustable shelves purely a token feature. You think, “Oh, this Billy shelf is very flexible,” but in reality, after the second adjustment, you notice: the holes are hardly usable anymore, the dowels sit loosely, and the whole shelf feels unstable.
Who knows, maybe a system with screwed panels or special clips would be a better idea, but that would probably ruin the price.
Le_kin
18 May 2021 10:07
Regarding the question of why adjusting the shelves in Billy often causes problems, I would like to offer a somewhat more detailed technical perspective:
1. Hole diameter and tolerances: The holes in the side panels are factory-standard at about 5 mm (0.2 inches) in diameter, designed to fit the included metal dowels. However, the diameter varies slightly—sometimes minimally larger, sometimes smaller—which makes both inserting and securing the dowels more difficult.
2. Material and load capacity: The side panels are made of particleboard with a foil coating. This foil can easily chip at the edges if the dowels are repositioned frequently, leading to a less secure fit for the dowels.
3. Load distribution: The construction is designed such that the shelves only carry a certain weight. When adjusting the shelves, the force distribution on the side panel and dowels changes, which can cause stresses that might lead to breakouts over time under sustained load.
4. Assembly precision: Irregularities when installing the shelves (e.g., if they are not perfectly level) increase the load on individual dowels, which can result in instability.
My assumption is that the problem mainly arises from the combination of material quality, manufacturing tolerances, and assembly practice.
My question to the original poster: Do you notice these problems primarily with shelves that have been repositioned multiple times, or already during the first adjustment?
Guylau
18 May 2021 10:24
Le_kin schrieb:
My question to the OP: Do you notice these issues mainly with shelves that have been repositioned multiple times, or already after the first adjustment?
Thanks, Le_kin, for the detailed analysis!
In my case, the problem actually occurs already with the first repositioning, but it does seem to worsen the more often the shelf is adjusted.
It often feels like the metal pins fit too loosely, or that the drill holes aren’t precise enough, causing the shelf to shift slightly or tilt.
The material quality—especially in older models—also seems to play a role, as the hole at the edge sometimes frays just a little.
I’m particularly interested in whether this is technically related to the type of material used (particleboard) or if improved versions might be possible.
