ᐅ What key points should I pay special attention to when assembling the Ikea Besta system?
Created on: 27 Sep 2022 09:16
pijapeo
Hello everyone, I am currently planning to assemble an Ikea Besta shelving unit and would like to benefit from your experiences. Specifically, I am interested in which screw points I should pay special attention to during assembly to ensure stability and durability. Are there any areas where extra care is needed or where mistakes often happen during screwing? It would be helpful if you could also share tips on how to avoid common pitfalls or which screws must be tightened very carefully. Thanks in advance for your advice!
BOLUKEO
28 Sep 2022 09:11
The dowel holes on the sides are extremely important. If you don’t insert the dowels correctly or drill inaccurately, everything will end up crooked. Check the holes before screwing in the screws and use a hammer carefully to fully insert the dowels.
JAMESONB41
28 Sep 2022 10:45
Don't forget: The screws in the sliding door track systems (if you have any) must be aligned precisely. Otherwise, the door may stick or not close properly.
Timofa
28 Sep 2022 11:13
PeoDaniel schrieb:
And if you attach a shelf to the wall, the screws used must be a dedicated fixing point with a high load capacity – no compromises here!
+1, definitely remember to use wall anchors! Especially with heavy Besta shelves, it's often worth investing in better wall plugs. I once had a minor accident because I installed the wall fastenings too loosely; you only realize the risk when it’s too late. Safety comes first!
Leote
29 Sep 2022 07:38
I would also add: The edge strips on the sides must be installed neatly to ensure the screw connections hold properly and no material breaks off.
Jensson
29 Sep 2022 08:57
Timofa schrieb:
I once had a small accident because I had fastened the wall mountings too loosely, and you only realize it when it’s too late.
That’s exactly why I always recommend replacing the supplied fasteners with high-quality alternatives whenever possible. For example, using Fischer plugs instead of simple plastic anchors. This makes a big difference, especially with taller or wider Besta shelves.
