ᐅ What safety measures are important when assembling the Ikea Hemnes?
Created on: 28 Dec 2022 09:37
NeofitpeHello everyone, I am planning to assemble an Ikea Hemnes furniture piece soon and want to focus especially on important safety measures to avoid both damage to the furniture and injuries during assembly. I am particularly interested in tips for safely handling the materials, the proper use of tools, as well as advice on stable construction and secure wall mounting. Do you have any experience or specific recommendations relevant to Hemnes furniture, for example to prevent tipping hazards or to make optimal use of the included fixing materials? Thank you for your support!
Z
zarHenning28 Dec 2022 10:03With Ikea Hemnes, it is important to always secure the wardrobe to the wall to prevent tipping. Use the included plugs and screws, and make sure the substrate is load-bearing. Sort all parts carefully and follow the instructions step by step.
For assembling the Ikea Hemnes series, I strongly recommend the following safety measures:
- First, check that all parts and screws are complete and undamaged, as missing or defective components can affect stability.
- Use only the appropriate tools to avoid damaging the materials or causing injury. A screwdriver with the correct blade width is especially important.
- Wall mounting is essential because the furniture can tip over easily during use without it. Use wall plugs suitable for the specific wall type (concrete, brick, wood).
- Ideally, work with a partner to safely handle the furniture, especially when lifting it.
- Be careful not to overtighten or undertighten screws. Overtightening can damage the material, while loose screws reduce stability.
Following these measures will reliably reduce both accident risks and subsequent damage.
Neofitpe schrieb:
I am especially interested in tips for the safe handling of materials, the correct use of tools, as well as advice on stable assembly and secure wall mounting.To add, for Hemnes-type furniture, often made from solid pine, it is important to pay attention to appropriate mounting surfaces. Using flat and clean supports prevents scratches and the risk of tipping over during work. Always lay the parts down gently and avoid dropping them on corners.
Furthermore, wall mounting not only prevents tipping for safety but also protects children. Therefore, it is essential to use the included safety brackets or alternative products and install them according to regulations.
The assembly process should be carried out calmly and precisely to avoid over-tightening screws or misaligning furniture parts. If possible, tools like a rubber mallet or wooden blocks can help with fitting components without causing damage.
