ᐅ Are there specific mounting options for Ikea Hemnes cabinets?
Created on: 27 Apr 2021 08:37
ethan48Hello everyone,
I wanted to ask if there are any special mounting options for Ikea Hemnes cabinets that go beyond the standard installation? Specifically, I’m interested in whether there are stable and secure solutions to firmly anchor the cabinets to the wall, especially when placing them in a spacious corner or even connecting multiple cabinets together. I’m not referring to simple screws, but rather solutions that are explicitly recommended for Hemnes or similarly designed furniture, possibly from Ikea itself or third-party suppliers.
Has anyone had experience with this or can recommend particular products or techniques that have proven effective? I want to avoid the cabinets wobbling or tipping over, especially if they are tall and might be holding books or heavy items.
Thank you in advance for your tips and advice!
There are no special Ikea mounting kits for Hemnes cabinets other than the standard wall mounting hardware. It is best to use the included metal brackets and suitable anchors for your wall type.
Alternatively, standard furniture connectors or metal brackets are a sturdy solution if you want to join multiple cabinets together.
Hey,
I can only agree with what Israel62 says: The most important thing is a good wall mounting – that way, nothing really wobbles.
If you want to combine several Hemnes units, you can simply connect them with brackets, which are available at any hardware store. That way, you’ll have the perfect IKEA cabinet Tetris! 😉
And don’t worry, if mounted correctly, the unit will be rock solid.
To answer the question precisely: Hemnes cabinets do not have special mounting systems patented by Ikea that go beyond standard wall mounting. The included metal brackets are solid enough for most walls, but depending on the wall material, different types of anchors should be used to ensure maximum stability.
If you want to connect several cabinets together, I recommend sturdy steel connectors that can be installed inside. When doing this, keep the following in mind:
- Check the wall type (e.g., concrete, drywall, brick) and choose the appropriate anchors accordingly
- Avoid quick installation of wall cabinets without verifying the load
- If you plan corner solutions, an additional screw under the adjoining edges of the cabinets often helps
Using longer screws will void Ikea’s warranty if any damage occurs.
I would be interested to know the height of the cabinets you want to mount and the exact weight involved.
Palenar schrieb:
I would be interested to know how tall the cabinets you want to mount are, and exactly how much weight they will hold.Thanks for the hint! My cabinets are about 180 cm (71 inches) tall each and are expected to carry around 50 to 60 kg (110 to 132 lbs) of used weight, mainly books and some decorative items. I will mount them on a concrete wall. I also plan to connect the cabinets side by side to ensure greater stability.
Unfortunately, I cannot fully screw them into the wall because they are located in a corner, and I can barely access the back of one unit. For this reason, I am considering reinforced connecting brackets between the cabinets.
In your case, with a height of 180 cm (71 inches) and a weight of 50-60 kg (110-132 lbs) per cabinet, it is definitely advisable to secure the cabinets to the wall and additionally connect them to each other on the sides.
This is how I would proceed:
- Use heavy-duty anchors for fastening to the concrete wall to ensure maximum load capacity.
- Use sturdy metal brackets for the side connections between the cabinets. Make sure these are installed not only at the front but also further back inside the cabinet to prevent tipping.
- Check if you can even mount brackets on the outside at the corners of the cabinets to create extra stability.
A common mistake is using screws that are too short or relying on only a single fastening point, which can lead to tipping risk later on. Using multiple fastening points effectively prevents this.
If you want, I can gladly send you a detailed list of the required screws and brackets.
