ᐅ What mistakes should be avoided when assembling the IKEA Hemnes furniture?
Created on: 4 Apr 2024 17:23
lametodiHello everyone,
I would like to start a discussion on the topic “Which mistakes should be avoided when assembling the IKEA Hemnes series?” Since the Hemnes system presents some typical challenges, I am particularly interested in which pitfalls other users have encountered during assembly or have managed to avoid from the beginning.
I am especially concerned with common assembly issues such as misaligned parts, screws tightened too much or too loosely, and generally dealing with the often rather sparse instructions. Who can share their firsthand experience about which mistakes are frequently made when assembling Hemnes models (e.g., dressers, beds, or shelves from the series) and how to best avoid them?
I look forward to a detailed and practical discussion!
Regarding your question, lametodi: For Hemnes, I recommend avoiding the following mistakes:
- Do not tighten screws fully right away. First, assemble all parts loosely, then adjust and finally tighten. This helps prevent misaligned connections.
- Precise alignment of the back panels is crucial. Many overlook positioning the back panels exactly, which weakens stability.
- Use the correct tools. Hemnes involves many cross-head (Phillips) and hex screws, so the right tool must be used to avoid damage.
- Follow the assembly instructions in the correct order. Some skip steps, which later causes fitting problems.
These are the most common pitfalls I know from reviews and my own experience.
I would like to add some details about the assembly, especially for Hemnes dressers:
- Preparation: First, lay out all parts neatly and check according to the manual whether screws and wooden components are complete. Identifying missing parts early saves a lot of trouble.
- Attaching the back panel before the main structure: With Hemnes, the back panel is not just a cover but contributes to the stability. Often it is attached last, but it is better to fix it early on. This keeps the furniture stable throughout the rest of the assembly.
- Inserting screws carefully: Over-tightening screws can crush the wood or damage the threads. It is recommended to use a cordless drill at low speed and torque.
- Avoid using force: If something doesn’t fit, it is often due to the wrong assembly order or twisted parts. Check again before applying force.
- Fit of the drawers: Hemnes drawers often show issues with the drawer runners. I recommend aligning them precisely and checking the guide rails on both sides with a square or level.
Now a question for you: Do you use any special tools or will you assemble everything using only the provided screwdriver? This can significantly affect the time required and the risk of errors.
bapar schrieb:
Now the question for you: Do you use any special tools, or do you plan to assemble everything only with the included screwdriver? This can greatly affect the time required and the risk of mistakes.That’s a good point! I often experienced the same with assembling the Hemnes: The included tools are basically okay, but after working for a while, I quickly noticed fatigue and less precision when screwing.
In those moments, I always reached for a small set of Phillips bits and a cordless drill. This not only reduces the chance of errors but also makes the assembly more comfortable.
I also think communication is important: If you carefully consider in advance which variations of the Hemnes model you are buying—since drilling holes or slots sometimes differ slightly—you can avoid assembly errors. It’s not uncommon for people to confuse parts and then try in vain to make them fit.
Finally, a quick tip: Document each step with brief notes or photos so you can later review the sequence if needed.
